Nitrous, Boost Leak?
In theory it may not sound like a good idea but in reality the combo makes stupid power on the stock turbo, with a 50 shot I was trapping 122, now witha 75 shot and a new mix of methanol the car should trap an easy 126 on stock block...
You can buy a 1/16 tap to tap it in the I/C pipe. It is like $10 or $15 from NX or NOS.
I have NX wet kit on my Evo and I sprayed a 75 shot for 3 years trapping 125mph. Never had any issues. The motor was still running and making crazy power when I pulled the motor to rebuild it. My car was flashed for the mods I had on the car. I installed the NX kit used the jets they told me to use for a 75 shot. Put in my wide band and went and sprayed it. It was tad bit ricer and pulled better timing so I left it like it was. I was trapping 115mph to 116mph in the 1/4 off the spray and with the 75 shot it was trapping 125mph....
Meth will effectively slow combustion by raising octane, allowing for more timing and higher boost. Nitrous will accelerate combustion due to a 02 rich environment, requiring less timing but not necessarily impacting boost. The two are diametrically opposed. I don't get it.
So your saying that nitrous cars cannot run on 115 octaine because the increased octaine is hurting the nitrous' effectivness. I understand where your coming from, but I have experence with nitrous cars, with meth cars, and with two turbo trans ams running 10's and 9's on meth and nitrous, Im sure if I ask them there not gonna say that losing boost as a result of removing there meth will make them faster.
No, I will be making signifigantly more power. I also fail to see the risk, people have used nitrous on cars for years straight, its all in how you spray, how much you spray, and if you are being safe. Im spraying a 50 shot, thats it, I will be going to 350 hp from 300, people have made 500 plus on stock block, why would this be any different with added fuel to keep things safe? Plus camshafts will cost me 900 installed. Where as this cost 150 and I know how to install the kit myself.
the last single fogger setup I ran, I had a welder put a "dot" of aluminum on the upper intercooler piping, basically giving me enough material to feel comfortable tapping it, and knowing it was going to stay and not strip out. Epoxy might work, but if you can find a welder who can weld aluminum, I think this would be safer.
Not that it's important, but I think I understand your logic now on how you plan on getting to your goals. As you are suggesting, there's more than one way to skin a cat. Good luck.
Everybody is scared of the juice. I was also until I really started doing my homework. If you have the ability to monitor AFR and knock, you will be fine with a 50 shot. One tip though. You should really have a wideband to dial in the correct fuel jet. The NX chart was not even close on my car. With that said, it is by far the best bang for the buck thus far. I should also say that I have a spare engine on the stand, but I do not expect the N20 alone to cause a failure. It will be the years of beating the snot out of it that will eventauly take it's toll. Sure like any mod it is a risk, but one that I am willing to take with my eyes wide open.
Cammed with what camshafts? And full bolt ons. Im not wasting money on bolt ons that cannot be used with a big turbo. And yes, I do agree with you, why do nitrous when cams are a safe alternative. I have weighed the pros and cons of nitrous, and like ^^^ he said, lots of people are afraid of nitrous. Just gotta research it. And Yes, I do need a wide band to dial in. My next major purchase will be a nitrous pressure gauge, EGT, and an AEM uego wideband. Just the Nitrous gauge will cost me more than my whole kit did. I will be completing full IC piping with a FMIC, tomei 280's with full valve train, and meth, in order to run low 11's stock turbo with a built drive train including front and rear LSD, carbonetics twin disk carbon carbon clutch, and shep t-case and tranny. Thanks for your help all.
TwStDeVo
14
Aug 19, 2005 07:00 PM
1mbrews8
Nov 20, 2004 07:56 AM
