TREperformance fuel pump
Yes these pumps are better then walbro.
There are a few points that make it better the way the pump is setup it can make more power then walbro i really cant explane how it works its all in the way the pump is made something like the way B/R makes the walbro put more output its like the same thing.
The coating on the outside of the pump takes heat better which is huge as far as the life of the pump goes so it will last longer. Cooler pump = better gas flow.
Im going to have to say you made a good choice on your buy budy and its a bolt on as well it should only take you about 10mins to change.
Naw its not theses pumps have been around for some time now. They work great. One pump is good for around 650 then it starts to break up with all stock fuel lines and fpr, rail. If you where to upgrade everything this single pump should be good for 750 maybe a lil less just becasue its not as restrictive.
[QUOTE=evilevo22;3839685]so i am happy with fuel pump without a tune how much whp will this add and after tune about 20 correct
Huh???????? I have never heard about anyone making power from just bolting in a fuel pump
In terms of output, THESE PUMPS ARE NOT CAPABLE OF SUPPORTING HIGH HP applications in an Evo at the boost pressure that an Evo requires to make high HP in single pump configurations. Look at the volume/pressure chart on the TREperformance web page http://www.treperformance.com/FuelPu...FuelPumps.html and you'll see that at 65 PSI (which is approximately base fuel pressure of 43lbs + compensation for 20 lbs of boost), this pump outputs approximately 140 liters per hour. At 70 PSI (25 lbs boost), the pump outputs about 130 liters per hour. If you're running a motor that can make 600HP without a turbo, or at lower turbo boost, then the pump can support higher volume (at these lower pressures), but that's not ordinarily the case with high HP Evo motors.
Buschur ran out of fuel at 530HP with a single Buschur modified Walbro High Output pump, which has stronger pressure/volume characteristics than this pump. No way this pump will carry higher HP than Buschur's H.O. in a single pump configuration. Probably not more than a 255 Walbro, either, although I'll leave you to check the Walbro flows for comparison.
Fuel volume AT THE PRESSURE REQUIRED is the critical calculation that must always be made. Don't assume anything without doing the calculations! Know how much fuel your motor will require for your HP goals, and then make sure your fuel system will deliver 20% more than is needed at the pressure you'll need. Don't go cheap on a pump, or when you're motor goes lean from pump lack of output or failure, you'll get to pay for a full rebuild. Proper supporting mods are the safety margin that is necessary for high performance.
You do have a point which i agree with you. I have seen this pump on a 37R 2.4L evo @ 29psi Ran up to 590whp without a problem. I wish i had the dyno sheet to show you. This has been tested.
If i had my car back i would test it out but i have upgraded fuel system in my car. So it wouldnt be the same as a car with stock lines and wireing.
But i agree with you 100% now that i look at the charts. But then i dont get why he would be able to run it up to 29psi without any problems and get the whp he got. If i right he runs a weldon fuel pump now so it would be pointless to ask the guy how the pump setup worked. Ill call him and find out.
