Advice welders
Advice welders
I have a Magnaflow Ti catback and I wanna have the neckdown at the cat flange corrected...my question concerns welding steel tubing to titanium tubing? Is it any different than welding steel to steel? Sorry for the dumb question.
im pretty sure its nearly impossible
No... I work at a power plant welding... and you have to weld titanium/steel/iron just about every kind of metal to every other kind of metal... trust me it can be done it just takes alot of skill
hey, dude trust me it can't be done i work at a muffler shop and i had similar problem once with a z06 (cat back are titanium) the owner asked me to remove the stock mufflers and put some flowmasters the guy was to cheap to buy a catback so, i cut them off and what was my surprise when i was trying to weld the flowmasters?? IT COULDN'T BE DONE WITH NOTHING MIG,TIG AND EVEN WITH A WELDING ROD COULDN'T GET IT DONE but some guys say that you could pull it off, try it and then post what happend
It will look like Fido's ***. Ideally to weld Ti it should be to another piece of Ti and should be in an inert atmosphere.
I have never seen anyone weld Ti to steel. I'm not saying it can't be done but, I would try to avoid if at all possible.
Do a quick google search and you will see your answer.
As far as the Shuttle, Ti is structural and extremely light weight. Not used as a thermal protection system as that is the function of the carbon-carbon and tiles.
95b18ccivic
Oct 10, 2016 12:33 AM
GNV Motorsports
89
May 29, 2007 11:55 AM
