Hard to go into gear?
Old Jan 10, 2007 | 06:06 PM
kjewer1's Avatar
First is synchronized. I also heard from a reilable source that EVOs have synchronized reverse gears too, and I'm inclined to believe it. Reverse in this car is nothing like it was in the non-synchro 1g and 2g DSMs.
As far as not being able to get into gear, I fought with the problem in cooler weather for an entire year on an aftermarket single disc clutch. I tried everything, and eventually just accepted the fact that it would be like that until I sent it out for my period shep rebuild. To my surprise, an exedy twin completely solved the problem.
Obviously I'm not expecting people with this problem to go out and upgrade the clutch again, but I don't think you will find an easy solution to this problem.
Old Jan 10, 2007 | 06:18 PM
GEARS's Avatar
Originally Posted by AngryJonnie
You sure about that?
Can you put it into 1st gear at 30mph with the clutch all the way diown?
I don't think so, I think you'll find it will go "kkkkrrrrcccuuuunnnnch"
Triple synchro 1st & 2nd
Double synchro 3rd & Reverse
Single synchro 4th & 5th and if you have an MR a single on 6th as well.
You should be able to stuff it into 1st gear even at 60mph but who'd want to do that?
Old Jan 14, 2007 | 08:42 AM
Kilratio's Avatar
"As far as not being able to get into gear, I fought with the problem in cooler weather "
I noticed after I've been driving the car for 15-20 min I dont notice it anymore. I'm thinking its when its cold its happining.
Old Jan 15, 2007 | 03:01 AM
kjewer1's Avatar
I saw the same thing. After the 20 min ride to/from work for example it will work fine.
Old Jan 15, 2007 | 05:44 PM
Chris Pana's Avatar
sounds like your clutch is 'dragging' i.e not disengaging. It happened on my exedy hyper single not long ago. It evertually came good over a day or two's normal driving.
Old Jan 15, 2007 | 05:56 PM
nObject's Avatar
is the car fully warmed up? change the tranny oil and go from there.. I used to havew the same problem until I got a fluid change then it went like butter.. my twin disk is a little bugger trying to get in but thats the way they are..
Old Jan 15, 2007 | 06:29 PM
tehforbes's Avatar
yea i recently put the exedy twin disk in too.....shifts great when rolling down the road but sometimes from a stop it is a little finicky!
FX11
31
Feb 12, 2019 09:54 PM
d-sport
Oct 27, 2016 12:51 PM
mrmiller
Mar 14, 2016 05:06 AM
Harumsevo
Jul 30, 2013 06:19 PM
aycynokia
May 10, 2011 06:33 AM
Quick Reply: Hard to go into gear?
