20G LT, 1st. day review.
#77
Well, You are in luck...They do have such a program.
http://linux.forcedperformance.net/m...e=Lancer_Turbo
#79
Guys, here is a link to the dyno results: https://www.evolutionm.net/forums/sh...d.php?t=248112
#80
Show me one of your logs where you have your boost set at 25 psi and it hits it right at 3500 rpms like you are saying on the stock turbo!
It depends on your mods and tuning.
The graph was so that everyone gets an idea of the boost curve. Each car and set up is different, even on the stock turbo, you can get different curves.
Take a look at this other pic, my old stock turbo.
See how I did not hit full boost until 7800 rpms. The curve can be manipulated with the fancy electronics, .
But, if you look at the whole graph, and look at the 20G LT one I posted earlier, you can see that as both turbos spool, the graph looks almost identical. Both going almost vertical at the bigining of the spool. I like an almost vertical boost curve at the begining of the spool, what ever turbo. I think everyone does. This turbo spools almost like stock, you can believe it or not. I showed my side of the story. Only thing left now is to try this bad boy in action, .
That is what I wanted you guys to see.
#81
That is a pretty fast boost spike my friend, .
Too bad it tappers down almost a full 7 psi by red line.
I think we were talking to that other guy SPECTRE and his tune, but I am glad you found your own log and posted it. It looks like you are really happy with that graph!
#85
Question?
So, wouldn't it be better to use the stock IX actuater if your going to run like 20-21psi. I read somwhere that it will eliminate the boost creep or hump!
RallySport Direct
Oct 31, 2008 05:07 PM
David Buschur
909
Jun 22, 2008 06:20 AM
Mellon Racing
12
Jan 27, 2008 05:59 AM
MR. Birdie
55
Feb 8, 2007 01:23 PM
David Buschur
485
Dec 8, 2006 03:39 PM
