What your EVO needs for a fuel system, facts.
Old Jan 14, 2007, 07:23 AM
  #31
David Buschur's Avatar
Alright, I got called out on my math by l2r99gst and he was correct. I accidently figured these HP levels at 80% like you would a duty cycle on an injector. So, I made a mistake
The original post #1, will be fixed immediately to reflect the correct information.
Sorry for the mistake, I used the wrong damn formula.
Old Jan 14, 2007, 07:46 AM
  #32
CO_VR4's Avatar
Dave,
Would you share the formula you're using for calculating the flywheel HP that the pump will support?
All formulas make some assumptions that generalize among motors. My calculations for flywheel HP produce lower supported HP numbers than your formula apparently does, but as long as everyone understands that these don't relate directly to dyno numbers, we're all on the same page. Drivetrain losses would reduce the flywheel numbers by 17-25%, depending on the 4WD system, so 600HP flywheel might translate to 480HP measured on the dyno...
What was useful to me in reviewing your numbers was (1) that there does not seem to be much difference in availalbe fuel volume flow comparing the stock Walbro and the HO Walbro,unless you're running more than 40 pounds of boost and (2) that even using your HO modified Walbro, your direct dyno experience was that you documented fuel starvation effects at around 500+ HP dyno HP at the wheels. You adjusted the fuel curves and used bigger injectors to work around the problem before the dual pump solution, right?
Old Jan 14, 2007, 08:09 AM
  #33
l2r99gst's Avatar
No biggie, Dave. I figured you added in some sort of safety factor into your calculations, like any great tuner would.
Thanks for the great product and all of the testing that you put into this.
Eric
Old Jan 14, 2007, 08:13 AM
  #34
purevibez's Avatar
i know what im buying. thanks dave great write up. ive been looking into a twin pump set up to fuel my stage 3 head and turbo upgrade.i guess ill be calling jarrod
great job as always
Old Jan 14, 2007, 01:32 PM
  #35
raiceboi697's Avatar
well i can see where my money will be spent. truly gangster david!
Old Jan 14, 2007, 01:39 PM
  #36
EVOlunchbox's Avatar
Great write up Dave!
Old Jan 14, 2007, 04:11 PM
  #37
evilempire76's Avatar
Great write up! Very clean looking double pumper setup.
Old Jan 14, 2007, 06:47 PM
  #38
LuxuryBroker's Avatar
thank you for ALL your time spent and given back to the Evo community !!
Old Jan 14, 2007, 07:01 PM
  #39
The BSFC I am using is .6. Simply take the lb/hr and divide by .6.
Yes, I was able to get the car to run/make power with a much larger injector than the car needed even with the pump falling off.
Old Jan 14, 2007, 07:52 PM
  #40
Frenchy4g63's Avatar
Could this be modified to use a different sized pumps?
Old Jan 14, 2007, 08:01 PM
  #41
jordo's Avatar
I personally like the FullBlown system better, its a complete CNC top which replaces the entire stock plasic (crappy) setup. Its also cheaper, and it gives you options do use -10an stainless lines instead of stock rubber lines.
Old Jan 14, 2007, 08:55 PM
  #42
trinydex's Avatar
just a problem of it can be retrofitted to fit the denso 50mm supra twin turbo 1040 pump or whatever it's called.
Old Jan 14, 2007, 09:07 PM
  #43
^^ Yup, that is the question. I did a little searching, the model number is 195130-1020, I guess RRE sells them. Denso has them listed at $190.00 MSRP on their site, so not bad at all. Suprisingly E-bay had them for $235.00.
I'm hoping either the Buschur unit or Full Blown unit can be modified to fit a pair of them, or single depending on needs. CO_VR4 was sending Full Blown a 1020 to measure and whatnot.. (I hope..)
Old Jan 14, 2007, 10:01 PM
  #44
Drifto's Avatar
First let's talk about the fuel pumps. Most every EVO shop that sells a Walbro pump for an EVO sells the GSS342 pump.
Here are the specs on that pump at boost levels that are important. This is flow testing the pump at 13.2 volts.
0 psi the pump flows 515 lb/hr
40 psi the pump flows 410 lb/hr
60 psi the pump flows 360 lb/hr
70 psi the pump flows 332 lb/hr
80 psi the pump flows 285 lb/hr
100 psi the pump flows 160 lb/hr
The reason these levels are important is it shows the fuel pumps are rated at 255 lt/hr at 0 psi. Nobody cares about that as the car doesn't run at 0 psi of fuel pressure.
From Walbro's own testing they show the 255 rating (255lt/hr=67gal/hr) at 40psi and 13.5V not 0psi. This from http://www.autoperformanceengineering.com/
Look in the left column and click technical then check out the 13.5V table. GSS342 is the "high" pressure 255 listed. Also shows a pic of the GSS340 (left), GSS342 (middle), and GSS341 (right).
Old Jan 14, 2007, 11:40 PM
  #45
Ultimate CC's Avatar
nice to see even more fuel options out for the evo...
Quick Reply: What your EVO needs for a fuel system, facts.
