Tilton clutch ?
I will really not know what the problem is until I tear the car down next weekend. This was just a theory presented to me by the Tech and Tilton.
I forgot to mention. This will only be an issue on some EVO's. It all depends on how well your EVO's transmission shaft is aligned. Some were very good from the factory and others were not. The one's that have an alignment problem are the ones that shear the splines on the disc pack.
I purchased mine in June 06.
Shad
Shad
I have the Tilton carbon / carbon and I like it. It's a little nosiey though. I don't mind it at all and I drive it through Atlanta's traffic like it's my beeatch!
It also holds the power well. I had a ATS triple carbon and like the Tilton MUCH better. We'll see how long it will last...
Here are 2 pics of the splines in both old/new disks.
The silver ones are the originals (My old Hybrid). The black ones are the up-date ones (I converted to full Cerametallic).
So you guys know, the color is one diffeence. The other is the new up-dated disk weights double the original one. The metal used in the new ones is much biffy.
You should not have one of each. They probably would not work together. The weight difference of each is significant.
The spline wear problem is not unique to Tilton clutches. It is seen on most multi-plate clutches that use seperate hubs of each disc, rather than a sprung hub. It can even happen to a single plate solid hub clutch. Tilton carbon clutch doesn't have the problem because it uses one hub (with a long spline area) to drive both discs.
A sprung hub is designed to absord the harmonics/vibrations caused when the engine fires. The more cylinders an engine has, the smoother it will fire and will have created less harmonics/vibrations. The EVO creates a lot of vibration/hamronics, especially if the cam has been changed. These harmonics caused the clutch disc/hubs to rattle on the input shaft splines. The sprung hub will absord it, but a solid hub will not and can begin to "beat" the splines from the clutch hub.
In addition, there can be great differences in alignment tolerances of the engine/transmission between cars of the production lilne. It is not cost effective for car manufacturers to makes sure the alignment in ideal and is another reason a sprung hub disc is used, as it will adjust for misalignment. Misalignment will be uneven load on the clutch hub splines and cause them to wear.
Lastly, the input shaft in the EVO is a "floating" design. It is not supported by a pilot bearing in the flywheel. Because it is not support, the input shaft will flex and alignment will change. The flexing of the input shaft will magnify as power increases. Becaue the alignment (betweem the input shaft and centerline of the crankshaft) is changing, uneven load is placed on the clutch hub splines.
There is basically a lot working against the use of a solid hub disc in the EVO. Some solid disc hubs users may be 50,000 miles while others may only get 500 miles. There are many variables that can effect the life. It is a trade-off. A sprung hub will absord the harmonics and adjust for misalignment, but it limited on the amount of power/abuse it can handle. It also has a higher inertia which will negatively affect high RPM shifting.
I spoke with Tilton a few minutes ago. With there earlier clutch disc packs the splines were not hard enought and have a tendency to facture. I will be taking everything apart next weekend to find out for sure. One plus is that a new disc pack is only $250 (retail) so it will not be to expensive to fix.
Shad
Shad
But, one thing is clear. You do have a Hybrid. The thing is, check the color of the splines. Silver lining is original disks, black lining is updated disks.
Dirk, is this explanation like the one my brother got on the DSM clutch install he did about two weeks ago? You know the one that told him to double check his install on a 1g DSM? Let's see, he's installed clutches in DSM's since 1989, probably a 1,000 of them by now.............
It's all good, we put a Centerforce DF in the car and it fixed it instantly.
Buy the Tilton, you'll like it.
Also while at PRI I was asking a few questions and they also offer a type of valve that reduces the fluid flow to the release bearing so the clutch doesn't slam into the flywheel everytime.
Since my tilton (hybrid) is almost on it's last leg i will be trying both of these and see if they lengethen the lifespan a bit more. I will be upgrading to a full twin ceremetallic.
