zeitronix / knocking
slowcar would be correct. there is only one extra input for the zeitronix and that is the user input. unfortunately it wont be very useful as it will only display it as 0-5V not actually as knock.
but doesnt cause the datalog to show voltage spikes if there are knock events.........and as long as its above the threshold of background noise, it should show up? Also isnt the ZT-2 capable of 76Hz aquisition rate?
i'm pretty sure it is frequency based for the knock. thus the analog input wouldn't be ideal for measuring the knock. you would want some kind of digital input to measure the frequency and then filter based of what freq. the knock is at... way more complex then tapping into the knock sensor wire with an analog input i beleive....
never tried it though, so i could be totally wrong.
Yes the Vishnu Knock buffer is the way to go. I was the 1st to hook it up to a Zeitronix. Just hookin the knock sensor to the user input does NOTHING (i tried).
I have my knock buffer for sale. Pm me.
lol, I didnt even notice that the link in this thread was to my ad for my knock buffer
So, I think the best system, would be one that allows you to log a sweep of the RPM band, or a few points in the RPM Band (exp. Low,Mid,High) so you would be able differeniate engine noise, from actual knock.
And these are the systems that I know of, that allow this with some sort of display:
Turbo XS Knocklite
PLX Devices R-500
AEM ECU (Combined with Data Stream Serial Gauge)
Now, I've been trying to get some info on the HKS Knock Amp, but I cant find much info about it, Also Apexi AFC II also can display Knock, but I dont have much info on that either, maybe someone on the board has some experience with these other units, or something else, that I havent mentioned.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
How does this compare, to the turbo xs knocklite? I've been looking at various products being offered on the market, and this is what I've learnt. Their are systems like MSD Knock Alert and Knock Link ,which from my understanding function the same way. They both have a visual display to show the level of noise/knock being seen by the knock sensor, and they both have a adjustment for sensitivity. The problem is, if you set the sensitivity for one scenario, that setting does'nt necessarily work well for another, you can imagine with the knock sensor signal rising with RPM, you could have the sensitivity set low at high RPM, which could be too low for anything to turn up on the display, at low RPM, were you could be experiencing light detonation.
Turbo XS Knocklite
PLX Devices R-500
Now, I've been trying to get some info on the HKS Knock Amp, but I cant find much info about it, Also Apexi AFC II also can display Knock, but I dont have much info on that either, maybe someone on the board has some experience with these other units, or something else, that I havent mentioned.![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Turbo XS Knocklite
PLX Devices R-500
With the knock buffer you see the all the noise. its up to you to determin what knock is.
dudical26
12
Jul 1, 2009 11:28 AM
Evo_Jay
Feb 7, 2007 07:21 PM
