Difference in Nisei FMIC Street & Competition?
#32
^^^^ Wow.. that is something really new to me. I know for a fact that you can retain the crash beam on the Evo 8. Perhaps the design on the crash beam on the Evo 9 is different I assume.
Carlos
Carlos
#34
#35
#37
#38
#39
Back on topic: Does anyone have personal experience with the new Nisei Competition Intercooler? It appears that most of this discussion has been regarding the street FMIC. I recently ordered the competition core( to replace my stock core). I'm keeping the stock plumbing for now. Im also going with the RRE GT3076R turbo kit in the next few weeks. I'm not sure if I will dyno tune once I'm done, but I will post graphs if I do.
#41
but like triny says, you can't go wrong at this point!
#42
but the fact is that's really as much as you can say. very few people have tried every core out there... and the people who have are going to be biased because they tested every core with a vested interest.
i've had both the street and the comp core and i can tell you that the comp core will prolly be better for a large turbo application. the street core is for people who want to keep a hot stuffy stocklike turbo.
of course some people will beg and scream and kick until they get what they want even though it's not the proper application and an alternative was recommended... and then turn around and say it's terrible and go to da intanet and tew evewyone.
so i'm here to tell you that the comp core is the proper application for what you've thusfar described and you won't be dissapointed... and i gaurantee that like the warehouse guy.
#43
Actually, the Nisei Competition Intercooler will be perfectly fine for the stock turbo, if not better than the street core. There is data that hasn't been released yet showing the comparison between the Street version and Competition version of the Nisei intercooler. This data is going to be released when Nisei finishes testing the products against the inventory of competitor products they have been aquiring. This data shows the Competition intercooler outperforming the Street intercooler on the stock turbo. That comes as no suprise though, which I will explain below.
The Competition intercooler can be looked at as more of a replacement or upgrade to the Nisei "Street" intercooler. The mission when making the competition intercooler was to take it to the next level in the pursuit for the perfect Evo intercooler. Nisei is constantly doing R&D on product and always brainstorming that next thing that will push the limits. The competition intercooler has similar dimensions to the street version. Thermal extraction is very close (marginally better on the competition). Where the competition intercooler totally kills the street is in pressure drop - which is over 1psi less than the 1.62psi the street intercooler tested at (at 20+psi). The street intercooler wasn't called the "street" intercooler until the competition version was released. Nisei did this to be able to distinguish between both models. However, both models can be put in the same category as far as application goes. Both can work on a stock turbo or a large turbo just fine.
The Competition intercooler is Nisei's next advancement in Evo intercooling. While it performs beautifully on a stock turbo, it's also performs phonominally on larger, more efficient turbos because of its enhanced flow. Since the stock turbo is commonly run at 20+ psi, the shaft speeds of the turbo are high. The increase in shaft speeds creates more heat. For stock turbo applications, the emphasis is on heat extraction. We've seen temps as high as 300 degrees at the turbo outlet. We saw this when comparing the street intercooler to the competition and also the street intercooler to a popular competitor's product. The competition intercooler has no problem exchanging this heat out while maintainning maximum flow. Even under some extreme conditions we were within 10 degrees above ambient temp. Larger, more efficient turbos produce more volume and boost at lower rotational speeds. The outlet temps remain significantly cooler than the stock turbo. The increased volume becomes the emphasis when selecting an intercooler in this situation, which the Competition intercooler also addresses exceptionally.
As said before, the competition intercooler is really just Nisei's next step at making the best intercooler for the Evo. When they push the limit again of Evo intercooling i'm sure you'll see a new intercooler come out or a revision to the existing product.
Now, why did Nisei discontinue the street intercooler? Most of it is explained with what i said above. The competition intercooler essentially replaced the old "Street" intercooler. Nisei plans on re-releasing the street intercooler in a more of a street application, where it will work with the stock undertray and not be as large. And, of course, you can still expect it will outperform it's competitors. This idea isn't in the works yet, but I anticiapte will be something we may see in 2007.
#45
copy cats!
A cast manifold for an EVO? BR did it first!!!
although i will say the Nisei intercooler an a buddy's evo is darn nice.. and one of the few parts he bought that wasn't a huge ordeal to fit...
