changed spark plugs, made puttering sound
id make sure you didnt damage the coils when you changed the plugs...If it runs rough, pull each coil individually to see if it makes the idle worse. If you pull one and the idle stays the same, its that coil/plug.
Check the gap of that plug, then check the resistance of the coil. It will most likely uncover a problem.
i just started it up again after reinstalling the wires.. it only popped once after about 30 seconds... but when i give the gas a little the whole car is shaking...
the motor isn't warmed up.. its baaaaarely over the line. could that have something to do with it?
it was still doing it so i pulled the 4th coil plug and it stopped... then i plugged it back in and pulled the 2nd coil plug and it did it again...
ive pretty much confirmed the coil plug furthest to the passenger door is damaged..
how, i dont know, i was super super cautious knowing how fragile these parts are.
thanks for the help
thanks for the help
SeahawksOilers
Apr 26, 2014 12:40 PM
User71421
May 5, 2012 08:43 PM
