Immobilization code????????
I want to know if there is any way you can reset the immobilization code without taking your car back to mitsubishi. i just purchased another ecu and I was wanting to know if I can do it without being charged for it by mitsubishi.
that's true, i forgot that key for the new ecu will not unlock your ignition switch. you need to be able to turn on the ignition to program a key. i don't know if you can pull the ignition cylinder out and remove the tumbler pins in the lock so that any key would work, then you should be good to go. do it at your own risk.
your only way out (w/o going to the dealership) is puting the "coded" key under the dash (keeping the ecu happy) near the ignition and just using the regular "old" key in the ignition to turn on the car...
it's an free software that allows you to flash your ecu with the use of a Tactrix cable. search for EcuFlash and Tactrix on here.
EcuFlash - http://www.openecu.org/index.php?title=EcuFlash
I always worry about who asks for inof like this, because your basially telling anyone who wants to steal an Evo how to do it.
No offense the1and onlyE call me a worry wart but I love my Evo.
The cant steal it without a key or rollback and if they really want it they are going to get it anyway it doesnt matter what kind of car it is
mady4g63
Nov 27, 2014 12:38 AM
