is rear motor mount worth the trouble?
Old Feb 8, 2007 | 09:14 PM
tehforbes's Avatar
Already have a front motor mount installed....and just ordered the cam gear side and tranny side mounts from AMS. I was also looking into getting the rear mount from buschur....or should i leave it be? any info would be aprreciated
Thanks
-Ryan
Old Feb 8, 2007 | 09:16 PM
Ultimate CC's Avatar
I think you will be fine with what you got, if you go to do your tranny or clutch do it then..
Old Feb 8, 2007 | 09:24 PM
tehforbes's Avatar
ok thanks for the info the thing is that i had a lot of shaking when going from a stop after i had exedy twin put in and then i had the front motor mount in and it help a ton. but now the vibrations are back so i am guessing that stiff mount wore the other weaker ones out. i just dont know which ones.....i think i may just buy the rear too but not install til after i put the two side ones in!
Old Feb 8, 2007 | 09:54 PM
Blue Evo 8's Avatar
Do them both
Old Feb 8, 2007 | 09:56 PM
tehforbes's Avatar
you mean do both the sides or do all three of em ? i just ordered all three of em so.....more than likely i will install all of em
Old Feb 8, 2007 | 10:12 PM
Blue Evo 8's Avatar
front and back
Old Feb 8, 2007 | 10:13 PM
jbrown's Avatar
do them all.
the pass. side one is easy.
the rear one and driver's side ones should be done at the same time, with a jack. will take 1.5-2 hours depending on your abilities.
Old Feb 10, 2007 | 08:12 AM
superflyevo's Avatar
im trying to figure out weather i want to do this to
TheLancerLife
Jul 10, 2017 03:06 PM
Emmy
Nov 3, 2016 03:51 PM
96eclipseGST
Mar 4, 2010 02:55 PM
NathanV
Dec 28, 2008 06:27 PM
superflyevo
16
Jan 3, 2007 07:07 PM
Quick Reply: is rear motor mount worth the trouble?
