serach search search!!!
I know people probably have already asked this so please no flaming, I have also searched for this topic and nothing really lead to anything. I have an 05 evo 8 with tbe, intake (just cone filter), tubular manifold, 75 shot nitrous, s-afc2, boost controller (spikes to about 25 psi and settles down to 22psi). I think thats about it. the afr's are set to around 11.0-11.5:1. currently im am having fuel cut issues in second or third gear generally. as soon as it happens i back off immediately. but when viewing my wideband it goes lean for about a second and then comes back. that is why i think it is fuel cut. but, my question is..... would i need fuel injectors along with a pump or just a pump? also what is the stock injector max out point, as far as hp? I have been wondering if 785cc injectors and pump would be enough. I think it has been kinda strange that may car has treated me this well with out anything to really support what i have. the car ran a 12.4@112.5 with stock exhaust, a filter, a boost controller set to 22 psi and afc on pump gas (alaska pump gas is 90 octane). I use torco to boost octane so i do not detonate. but, any help would be appreciated. thank you for reading.
1) Fuel cut is caused by surpassing a preset airflow volume in the ECU. Running so much boost without a proper tune (re: flash) is why it's happening.
2) That's an exorbitant amount of boost for 90oct - extremely dangerous. Are you saying you run torco ALL the time? Even that is not wise.
3) That combo of mods is destined for destruction.
4) You should never in a million years be running your car this way without a fuel pump.
5) Your Evo doesn't need injectors either, but in order to run an SAFC, you do need injectors so that you can remove a ton of fuel and thus combat fuel cut by fooling the MAF. This is a very poor way to setup a car, imo, when you could just flash it and stick with stock injectors.
Jesus, all those mods, that much boost, and spray!!! I am suprised you havent hit fuel cut while spraying and blown your motor into the ground. You need a fuel pump yesterday. That is the reason for your brick wall, unless of course, you are also untuned, in which case it is twofold, the lack of a fuel pump and what warr said.
yeah like i said im surprised that my car has treated me so well. and yes, i do use torco all the time with no ill effects. the gas up here is kinda strange for that fact that it all changes during the winter to a really oxygenated and alcoholed fuel to combat freezing. mind you it is Alaska. bascially i have nothing really working for me up here. no dyno's or any type of tuning facility. when i shot nitrous as well i did not hit fuel cut, which was surprising to me but meh. i have been looking into several different flashes. the buschur flash seems to scream to me the most. that or i was going to get an e-manage ultimate. thanks for the input though.
oh yeah i have checked the welds on the manifold.....i blew them to shreds hahaha. and i was contemplating a 10000 shot. dunno if that would be enough though
GT35REVO8
Jul 20, 2007 12:07 AM
Inn-Tune
42
Mar 11, 2006 01:32 PM
EvoTio
34
Feb 19, 2006 09:08 AM
