EVO VIII Upgrade Questions for Veteran Mitsubishi Owners
Old Jun 4, 2003 | 10:19 AM
EVOeight's Avatar
K&N now makes one of their FIPK for our cars? Can someone post a link and maybe some pictures?
Old Jun 5, 2003 | 01:33 AM
SmokinJoe's Avatar
I have a Greddy TT and used the HKS 2ndGen harness.. to my knowledge most TT's work with this harness.
Also, you dont need to hook up the ebrake wire and speed wire - making the install a 15min deal.
Does the Apexi SAFC have a harness??
Old Jun 5, 2003 | 02:29 AM
erikgj's Avatar
Forget the manifol, get a turbo-elbow
Old Jun 5, 2003 | 01:05 PM
BadBoyBeltran's Avatar
Can anybody come up with the EXACT best mods for our EVO's? Everyone seems to add a little "insight or theories" to these upgrades. Anybody have a proven and tested upgrades with upsides and downsides?
I am so confused!
Old Jun 7, 2003 | 02:20 AM
Incognito's Avatar
Originally posted by IUP200
you might want to be carefull running 20 to 21 PSi on these EVO's, to the best of my knowledge, a 16G shouldn't be run much hight than 19psi, which is accatually what it come set at.
if your running that at just the track, than I guess you shouldn't worry, but I personally would not drive everyday above 19 psi with a 16G in my car
From what I know, 16G's in the Evo will make power in the low 20psi range. I think AMS said their car boosted up to 25psi or something. I know lots of DSM guys that boost the **** out of their 16G's, and I'm sure they can't all be wrong.
21psi shouldn't be a problem on Evos, because from the factory, they run pig rich.
Old Jun 7, 2003 | 02:22 AM
Incognito's Avatar
I am so confused!
What is your definition of "Best"? Are you looking for the best drivability, most HP gains, least expensive, etc...
With the mods I have in my signature, I ran 12.41 at 109.5mph. I don't have experience with anything other than the stuff on my car, so I can't say. If 12.4 is good for you, then my list of mods will do it.
Old Jun 7, 2003 | 02:57 AM
KIDBANGA10's Avatar
what was the total cost of your mods?
Old Jun 7, 2003 | 11:29 AM
SmokinJoe's Avatar
Here is my plan of attack for adding mods to my car.
1. INTAKE - cheap way, drop in a K&N. Pricer way, RMR Intake with new piping to the compressor.
2. Exhaust - cheap way, 3" catback. Pricer way, Full 3" turbo-back with highflow or no cat.
3. Gauges - cheap way, Autometer Boost and EGT. Pricer way, Defi peak/hold/playback Boost and EGT. Add in a turbo timer here.
4. More Boost - cheap way, manual boost control and an AFC (HKS/Apexi). Pricer way, Vishnu Xede with control over the boost soleniod. Add a VTA BOV here.
Four Easy steps to mid-12s. Less than $1,500 the cheapo way. Somewhere along the line add a set of superlight 18" Volk CE28s with 245 meats. Mmmmmmmmm..meaty
More power?? Cams, hard IC piping, extrude hone the exh manifold and turbo elbo (yeah, it really does help).
More More power??? Turbo upgrade, larger injectors, fuel pump, clutch/flywheel, etc, etc.
Old Jun 9, 2003 | 01:48 AM
Incognito's Avatar
Around $2K, including the gauges.
drucea
Oct 2, 2017 09:26 AM
RavSpec
Dec 20, 2004 03:15 PM
turbo03oz
Lancer Aftermarket Forced Induction Tech
20
Sep 12, 2004 11:24 PM
Vivid Racing
10
Sep 18, 2003 10:46 AM
uranium9v
Jun 8, 2003 03:49 PM
