Titanium TBE
#31
just to add some others, hks kansai, i think amuse makes a Ti catback, and there is one more that i think jondemand sells but i cant remember it, i have heard the hks kansai, it sounds amazing
#33
I can't find the hks kansai ti cat back system. I can't find specs on them at all. I tried the www.hkskansai.co.jp but couldn't find them on their site.
#34
What he's trying to say is that titanium is not a good material for an exhaust system. Steel is better at retaining heat, because it is more dense. Retaining heat is the key to keeping exhaust velocities as high as possible. The higher the velocity the higher the power. If I was made of money I would buy an inconel exhaust system. It's better than steel when it comes to retaining heat. Just for your information.
ture....HOT exhaust flows better and faster than cold exhaust....
#35
just so u know, from an earlier comment..
most exotic race cars use inconel exhausts, from the turboback etc... believe me, i know... i crashed one with an inconel exhaust... wasnt my cost to replace.... but a 5 foot section of inconel pipe with heat coating was about 3600 bucks....
Ti can be worth it to save weight, but all exotic metals cost $$....
to each their own.
cb
to each their own.
cb
#37
i don't think the main reason why you don't see too many Ti DP is because of the hot temp. there are Ti headers for street bikes and they can get red hot. i think the main reason why is the because it's very hard to mandrel bend large Ti pipes and a DP have many sharp bends. Ti is a very good memory metal, that means it will spring back to it's original shape, it would have to be cast in what ever shape you want it in the first place. even Ti exhaust with minimal bends are section welded.
look at all the section weld on this Ti DP, that's a lot of labor. and even though section weld looks cool, it's still not as smooth as mandrel bends.
#38
Another reason not to use Ti for components that are subjected to high temp is, as i mentioned in the earlier post, Ti is a getter material - in the presence of a carburizing atmosphere, titanium carbide forms - it is a brittle compound and parts, especially with multi-segment welds will crack.
#39
alot of these companies dont use TI for the downpipes because it generates so much heat. Being that the downpipe passes right under the oil pan, it would probably generate hotter oil temperatures which are no good to your engine.
#40
The shape memory alloy is nitinol - binary alloy of nickel and titanium. Ti will bend and stay bent like any steel.
#42
Auto Produce Boss makes a titanium downpipe: http://www.apboss.com/english/images...pipe/evoti.gif
No one makes a whole turbo back as far as I know would have to combo this with a ti test pipe or cat and exhaust. This dp is expensive though like 86000 yen, pretty sick though.
Also fyi the Mine's skyline uses a ti dp.
#44
Titanium is not good when it comes to downpipes, period. It's not as good as stainless steel when it comes to heat resistance. It will be brittle under high heat. Debate over.
