how accurate is the stock boost gauge?
hey guys i was trying to find more info the stock boost gauge since i plan on running around 22psi which is ~1.5 bar which is max on the gauge. how accurate is the stock boost gauge? i'm looking at buying the prosports boost gauge but whats the sense of running 2 boost gauges. also is a AFR gauge needed without a wideband o2? i just got an autometer AFR gauge that i might sell to get a prosport gauge instead. the mods are going to be MBC, JunB.L exhaust, K&N drop in and a reflash. thanks in advance
I compared my OEM RS/MR boost gauge with three laboratory-grade mechanical pressure gauges, and the OEM boost gauge was within 1 psi of the lab-grade gauges. Unless you buy a gauge with guaranteed accuracy (that suits your desired accuracy), I don't think you're doing any better than the factory gauge.
