Crank walk or bad balance shafts?
Crankwalk hasn't been a problem since the Eclipse's. If I recall correctly it was isolated to a 6 bolt motor. We have the 7 bolts which are bulletproof in comparison. HOWEVER.... even a BULLETPROOF motor can get crankwalk when a heavy duty clutch/pressure plate is used..., OR excessive drag style launches are done...just FYI... If you talk to Mike W. at RRE, he will be able to give you much more descriptive insight.....
reason being the 2g 4g63`s had a push type clutch therefore heavy duty clutches were pushing on the crank wearing out the thrust bearings evos have a pull type clutch
think it solved the problem
by the way my car has the same 4k vibrating issue right now it happen after the cams were installed i had it up on a lift @ 4k the driveshaft vibrates badly i am 100% positive that my balance shafts are out of sync not the first or last with this problem when i fix it ill repost & share the details
It's only the eclipse 7 bolts that had the problem like you said, don't know how or why but if I remember correctly all the motors made at the DSM plant now MMNA were susceptible. Which is why people do the 6 bolt swap or the JDM swap which is a 7 bolt.
Maverickvf84
Jun 17, 2009 06:07 AM
smokedmustang
99
Nov 7, 2005 05:35 PM
