Loud Whinning Noice - Transmission?!?!?!
Old Mar 5, 2007, 03:25 PM
  #46
Silver06evo9mr's Avatar
Originally Posted by hondafan
GL-4 goes in the tranny, the TC uses GL-5. and if you can find anything official stating that the BG is GL-4 rated, please share with us.
6 speed uses GL-4 looked in my manual so i know thats correct. according to the shop BG is a direct replacement for the oem fluid rated gl-4
Old Mar 5, 2007, 05:36 PM
  #47
hondafan's Avatar
well, it's weird that BG doesn't endorse it with a GL rating. i don't like going by according to "blank" unless the "blank" is the company making it. did you find out if they used the right fluid in the TC? diaqueen LSD, not diaqueen gear. mitsu will probrably check the fluids to make sure they're the right ones for your warranty.
Old Mar 5, 2007, 11:21 PM
  #48
trnstr's Avatar
updates ? my car is also whining as well just got my clutch done about 4k miles ago I cant afford 1800 dollars got a clutchmasters stage 2 clutch no hard launches or anything on it either
thing is my car is running fine though its just the noise that scares the hell out of me
Old Mar 5, 2007, 11:41 PM
  #49
evrblazin's Avatar
well the shop it got it done at are members to this website, they also are very knowledgable and know what they are doing.
okay you should be fine then LMAO
Old Mar 6, 2007, 05:20 AM
  #50
well we will find out thursday ill post back
Old Mar 6, 2007, 05:35 AM
  #51
EVOL2003's Avatar
wheel bearing?
Old Mar 6, 2007, 05:39 AM
  #52
Originally Posted by EVOL2003
wheel bearing?
nope thought of that. only does it when its in gear and on the gas. stops when outta gear
Old Mar 6, 2007, 11:45 AM
  #53
trnstr's Avatar
mine still makes noise when out of gear on decelaration does yours do that as well Also does your car stil acelerate normally
Old Mar 7, 2007, 02:16 AM
  #54
accelerates pretty normal maybe a liltle crappy. and it bearly makes noise out of gear... really quiet though
Old Mar 7, 2007, 03:15 AM
  #55
vboy425's Avatar
i would say the synchro are done
Old Mar 7, 2007, 12:46 PM
  #56
dude its gotta be the T-case. there is nothing else it could be
Old Mar 8, 2007, 03:15 PM
  #57
ok so here is the update. long story short mitsu rep and dealer say that they think its comming from the "rear" of the car?!?!? wtf yea right. they changed my rear diff fluid which "was black and low", drove the car again and still the same noise. what a suprise right!!! so now they say i have to bring it back tuesday and they will put a listening tool on the frame to see where the sound is comming from. The reps think the rear. Everyone else thinks the "front".
If it is "rear" mitsu will cover it.
If its "front" then i will have to pay to tear t-case apart unless they determine it was a faulty part. Which it will be so i will have to pay for everything.
Either way im fuuucked. we all know its nothing but the t-case they are just BSing me around.
Best part of the story is later on i talked to the service manager who is really cool for about 30 min. He told me all this dumb stuff the reps were saying. When my aftermarket BOV went off he asked what it was.....this is why no one can get ANYTHING covered under warrenty!!!
Im screwed
Old Mar 8, 2007, 03:20 PM
  #58
emagdnim8's Avatar
sucks..
Old Mar 8, 2007, 03:30 PM
  #59
to say the least ^^
Old Mar 8, 2007, 03:43 PM
  #60
TxEvo8's Avatar
I've got the same issue, but have 65k on my car. really sucks
Quick Reply: Loud Whinning Noice - Transmission?!?!?!
