developed a 5th gear grind today!!! help
I too have the fifth gear grind. From what hear sometimes it is worse after Mistu works on it. So I left it alone. It only happens to me when I am above 5k as well. I found if you just delay your shift a little bit it doesn't seem to do it instead of slamming 5th.
^^ This makes no sense.
Mitsu will cover any work they do on your car if it's still warrantied.
So what if the effed up and got back a worse tranny...Just give it back to them until they fix it right.
Heck, drive their free loaner car until you get your car back from them, instead of driving around with a bad syncro that will just get worse.
Mitsu fixed my 5th gear grind at 4500 miles. Got my car back the next day.
Have 50K+ miles now with no issues.
Try using an aftermarket fluid. Shep recommends redline, TRE recommends BG II or the OEM 6 speed fluid. All 3 of these fluids are thinner than the OEM 5 speed fluid and help with synchronizer engagement. I have personally witnessed a 5th grind go away by using Penzoil/GM synchromesh (I recommend using BG over synchromesh though)
thanks for all your help guys.
i will first try to adjust the clutch so it grabs higher to see if that help.
if that does not fix it i will try thr bg2 fluid.
how high does your guys clutches grab at??
also about the warantee info. for sure the mbc and cams will void the warantee?
i'm just asking if i do have to get it waranteed what mods should i take off
1 Post
Dude DON'T use BG, the sh*t sucks.
I am using RP GL-5 when I go back together. This fluid is kinda sticky, tacky if you will, so it will cling to the sycro and help stop that gear fast for the fast shift
Don't beleive the BS about only use GL-4 fluid. If you read up on the 2 fluids, you will find that GL-5 is better because it has additives in it to help cushen the gears and protect them
I have been racing VW's for 9 years now and all of them use brass sycro as well and I have NEVER had gear grinding issues... and have ALWAYS used either AMSoil or RP GL-5
mines been grinding for years. when you shift to 5th you can double clutch lol and it wont grind haha.
or just let the rpms fall... ither or.. those are my solutions.. when i do my next round of mods with t67 i'll send my tranny of to get redone with a 4.11 also
I doubt adjusting the clutch will help any. If it is just the 5th gear grinding, and none of the other gears, its highly likely that you have a synchronizer engagement problem (which is a common problem with the earlier 5 speeds). A good aftermarket fluid will help, or even the OEM 6 speed fluid (if you can afford to spend $80/gallon).
03s have a tsb out for the syncros check your dealer, i had mine fixed @ only 14k miles and i really baby my car. No problems since and they put a clutch in while they were at it... and my car was modified.
