HKS Carbon Ti sound level? db?
Ive searched and all i've found is people saying "its not that loud". Well ofcourse thats all relative. So does anyone know the sound level of the catback system in decibels? Dont have to be exact but a close guessimate would be great.
It would be great if the hks owners could chime in and give their input. Details like sound @ cruising, WOT, idle would be great. Thanks.
It's not loud and obnoxious it has a low but not to loud tone. If you go to GruppeS.com they tell you the db level. It also depends on if you're cammed, or if u have a hiflo cat, or test pipe. I have cams, and a hiflo cat so it sounds louder than a stock evo with the HKS TI.
Gruppe-s.com has this info:
HKS Carbon Titanium Exhaust (bottom)
Type: Cat-back (USDM)
Piping Style: 75mm Stainless Mandrel Bent, Polished
Tip Type: 120mm Straight Cut
Resonator: One
Silencer: No
Power Increase: 10-12HP
Great info but still no decibels...
Resonator: One
Silencer: No
ok, i just installed the HKS Carbon Ti on my car with a Perrin HFC and an Invidia DP.
i have been looking around for a dB meter the last couple days to get an exact number, but haven't been able to find one just yet.
all i can tell you is that it is a good bit louder than stock, but not obnoxiously loud. it doesn't drone on the highway, and sounds nice and smooth, with just a little break up during shifting.
i was worried it would be overtly loud when i was first installing it, but with a high flow cat and the large resonator in the cat back, it's not bad at all.
i am gonna keep looking for a dB meter though, i was thinking of calling some stereo shops next week to see if one of them would let me pay a couple bucks to use theirs.
i will update this thread if i can track one down.
im running that setup on my car, i have the helix dp and test pipe... it sounds great its not very loud at all compared to some of the other exhausts out there on the market. even at wot it sounds really good.
TURBO MAG. did the test. I have the magazine at home Ill post the db when I get home.
I have this exhaust with a hiflow cat, car has cams. This exhaust is not loud it has a mellow tone during cruising but at WOT it does wake up but it's a really nice deep sound. not raspy like other exhaust out there. My RnR tbe with the magnaflow muffler was louder.
FROM TURBO MAGAZINE
does not say if the evo had a test pipe.
stock.
idle 92db
3000 rpm 92db
RSR EX
idle 95db
3000 rpm 101db
ESPELIR JGT 500
idle 95db
3000 rpm 102db
BLITZ NUR-SPEC
idle 97db
3000 rpm 101db
HKS CARBON TI
idle 96db
3000 rpm 102db
APEXI GT-SPEC
idle 95db
3000 rpm 102db
SKUNK2 MEGA POWER
idle 96db
3000 rpm 101db
TANABE MEDALION CONCEPT G BLUE
idle 96db
3000 rpm 101db
TURBO XS
idle 94db
3000 rpm 98db
5ZIGEN MIRACLE FIRE
idle 97db
3000 rpm 101db
INJEN SUPER SES
idle 95db
3000 rpm 100db
GREDDY RACING TI
idle 98db
3000 rpm 102db
HOPE THIS HELPS !!!!
stock.
idle 92db
3000 rpm 92db
RSR EX
idle 95db
3000 rpm 101db
ESPELIR JGT 500
idle 95db
3000 rpm 102db
BLITZ NUR-SPEC
idle 97db
3000 rpm 101db
HKS CARBON TI
idle 96db
3000 rpm 102db
APEXI GT-SPEC
idle 95db
3000 rpm 102db
SKUNK2 MEGA POWER
idle 96db
3000 rpm 101db
idle 96db
3000 rpm 101db
TURBO XS
idle 94db
3000 rpm 98db
5ZIGEN MIRACLE FIRE
idle 97db
3000 rpm 101db
INJEN SUPER SES
idle 95db
3000 rpm 100db
GREDDY RACING TI
idle 98db
3000 rpm 102db
Tanabe Medalion Touring cat-back. $545
-80mm piping and 100mm tip.
-Under 93 decibels.
-This system requires no removeable silencer for under 93db operation at all rpms.
-The maximum decibel limit in California is 95 decibels.
-The high grade full SUS304 stainless steel Medalion Touring cat-back features a slim-line oval canister, and a special dual wall, angle-cut tip.
-Advantex Performance exhaust technology,
-Weight reduction - 1.2mm thinwall piping.
-Weight reduction - hollow exhaust hangars.
-Weight reduction - pressed flanges.
-Straightest form and mandrel bent.
-Tanabe is the first and only Japanese exhaust manufacturer with a dedicated USA division to have the ISO9001 quality manufacturing certificate . Because of the extreme difficulty
to obtain this certification, those who have the Tanabe exhaust system drive knowing they have one of the highest quality, most thoroughly developed systems in the world. Fitment
and function are always flawless, and each exhaust is fully supported by the Tanabe USA staff for tech and warranty.
-Under 93 decibels.
im confused from what is says on the turbo mag it is loud when hitting the gas but some of you are saying it's not, im getting an hks tbe and i hope its louder than the stock one but not loud enough to get in trouble
