Diesel fuel inside the OEM lifters???
Old Mar 13, 2007 | 06:58 PM
Paul Nelson's Avatar
Originally Posted by jrsimon27
maybe jamm lifters are different somehow??
If im not mistaken there is a whole post on bleeding lifters in here by one of the moderators.
https://www.evolutionm.net/forums/sh...=135316&page=2 Here ya go!
Old Mar 13, 2007 | 07:03 PM
jrsimon27's Avatar
yep and he doesnt explain anything on refilling the lifters with diesel fuel i all ready read that whole thread
Old Mar 13, 2007 | 07:07 PM
digger70chall's Avatar
diesel full just makes no sense, it has to be for cleaning only...
one thing you definitely don't want to do is get diesel hot and compress it over and over again
Old Mar 13, 2007 | 07:09 PM
jrsimon27's Avatar
then mitsu tech and books are going nuts
Old Mar 13, 2007 | 07:10 PM
also Step 3 states that you are expelling contaminated oil ie not fuel
Old Mar 13, 2007 | 07:17 PM
Ive been running these and revving them to 9500rpm with no problems 3gen lifters Ive seen them for around $10 each
Old Mar 13, 2007 | 07:19 PM
jrsimon27's Avatar
yeah but step 9 and 10 says that you need to refill them with diesel and reinstall them to the engine as soon as possible.
Old Mar 13, 2007 | 07:22 PM
jrsimon27's Avatar
My mechanic sells these lifters for $10 each. Ive been running these and revving them to 9500rpm with no problems 3gen lifters
https://englishracing.net/catalog/in...h=108_22_27_32
this ones look like jam lifters
Old Mar 13, 2007 | 07:23 PM
electricevo's Avatar
no buddy you read it closer then
it says they need to be filled and left with diesel just read the last step which is #10
You made the threa without all the pics up. I didnt know you werent done so please do not talk down to me, buddy.
Ahh shoot im going to get in trouble for posting this im not a vendor
matyb's Avatar
mitsu may want diesel in the lifter because it is thinner than anyoil that is readially avail.
if you have a thick even 0 wieght oil it WILL blow out the seal in the lifter i assume the diesel will not seal as well and will more easily pass pass through.
you did not make a mistake by bleeding down your lifters during a cam install, you have to and if you have any noises it may be that you did not bleed them down properley.
Old Mar 13, 2007 | 07:25 PM
jrsimon27's Avatar
Old Mar 13, 2007 | 07:28 PM
jrsimon27's Avatar
what do you mean by pass pass through? what passes more easily engine oil and good explanation on the diesel being thinner
Old Mar 13, 2007 | 07:33 PM
AF-Evo8's Avatar
i used that page from the service manual when i did my install and i thought it was weird because the lifters were stiff when done, i thought they're suposed to be bled completely and allowed to fill back up by cranking the engine without starting it.
Old Mar 13, 2007 | 07:36 PM
jrsimon27's Avatar
yep this also confuses me they where bled so that they wouldnt be stiff but if you reinstall them again with diesel inside them then they are stiff again
maybe its what they said above that diesel its thinner then oil thus wont damage the internal seal
Quick Reply: Diesel fuel inside the OEM lifters???
