just got my evo ix saturday,, 2nd gear grinds
ahhhhh haaa
Just went out for a spin on i-95 you know neewby fever got off the ramp nailled it not pedal to the medal thou just 75%,,, did it from 1st gear all the way to fith hit 130 in no time dammmm this car is suppeeeerrrrr funnnn !!!!! i am loving it
anyhow, every gear is notchy ,, comeon evo experts talk to me, ohhh and second gear did not grind,
if some expert out there can reason this please do (here you go, it depends how and where i shift if i shif to 2nd at about 3k it wont grind if i shift at about 2.5k it may will, when i mean grind i mean, you can't hear it you just feel it on the shifter if you know what i mean.
also u have to replace the shift base bushing and linkage bushing. when ur rowing throug the gears in a spirited manner, the soft rubber bushings will flex and increase your chance of grind.
does this happen under load or just normal driving? If it is happening under load then it is very common because these cars don't like shifting fast under load.
Since your car is new I suggest you take it to the dealership and go from there.
I have a slight grind into 2nd and 6th very rarely. My car has 5300 miles and I just bought it. I found out that the tranny was just replaced b-cuz of the previous owner demanded there was something wrong. Unless they can REPLICATE it they won't do anything. Just wait til it gets worse.
heres the link to the Zaklee bushings, best $25.00 spent!
https://www.evolutionm.net/forums/sh...d.php?t=237515
I bought my IX back in Jan w/ 5 mi on it and I had 2nd and 3rd gears grinding on me. I granny shifted the car for about 1000 miles and it got alot better. Hopefully it will for you too.
I would keep bringing it in to the stealership if you are still concerned.
for Mitsu
for Mitsu
Dudes, the Tranny has to be broken in. It took my EVO about 2000 miles before the notchyness went away. Like every major part the car has to be broken in correctly. You can't expect a manual tranny to be buttery smooth right off the baot...come-on....give it some time to get worn in properly.....don't race it or act like you can dumpt the clutch until it's been broken in correctly thru time.....
A warranty is a warranty is a warranty......im so sick of these dealers trying to bully everyone......i would bring it back RIGHT AWAY just for the fact that you know you'l be modding your car soon, so take it in B4 they can hassle you about that stuff too.
thanks for everyones imput, i can see how different people have different opinions very good ones, i was the one who started the thread.
anyhow, it seems like my 2nd gear i getting somewhat better, but still sometimes i have to kinda mussle-it in, its under warranty i only have 1500k on the Evo ill take her back if the prob persist
thanks everyone
thanks everyone
