Shearer 35R dyno results
Old Mar 14, 2007, 11:03 AM
  #31
GPTourer's Avatar
How is the weather over there? Maybe you can get away with a little more boost if its cold outside, but not during the summer.
I thought the US system of determing octane was more complex then a lot of overseas markets, so that 98 for them would be more like 96 (if it existed) or so for us. So that our 93 would actually be better/higher octane then overseas 93. Where does Taiwan get its fuel?
Old Mar 14, 2007, 11:06 AM
  #32
Chris@nolimitmotors's Avatar
Nice numbers
Old Mar 14, 2007, 06:34 PM
  #33
Derek888's Avatar
8:5-1cr
weather here is is about 70 and its very humid.
I have no idea where we get our fuel from
Thanks!
Thanks!
Old Mar 15, 2007, 05:12 AM
  #34
deadbeatrec's Avatar
Originally Posted by 4TUN8
I'm not waiting for the boom sound, I wouldn't wish that on anyone, wtf man?
I will admit that I didnt see that it was 93 octane, but I was on my phone so that's my excuse hah...my other statements still stand though, it's a more efficient turbo, it could be very possible.
yes this is still true but the turbo is also pushing crazy more amounts of air then say a stocker. so even though its more efficent its also giving the engine more air.
honestly this is all speculations to what we have seen and known to be true. maybe this car runs super cool and has no knock issues and 26psi is fine on 93 octane. i sure as poo know that wont happen on my car. i tried to get more out of 93 octane with my set-up now with only 24psi and the timing was being pulled i lost about 15whp up top. so im very conservative at 21.5psi
Old Mar 15, 2007, 11:16 AM
  #35
AzBlackEvo8's Avatar
Just FYI - Taiwan has 98 octane available at every pump & HKS tuned it, those boys should know their shlt
Old Mar 15, 2007, 04:06 PM
  #36
kjewer1's Avatar
I've been running running 25-26 psi on 93 octane daily for the last 4 years at least. Some poeple need to back away from the internet and go do some logging once in a while. Even if you give up a couple degrees of timing to run the boost without knock, it has always resulted in more power for me. Another point worth making is that with DSMlink the CEL is triggered anytime knock exceeds whatever value you set, so I would have seen any random cases of knock from bad tanks of gas, and things like this. There is no problem running 26 psi on 93. I'm running it now in my EVO on the 20gLT.
The trick to high boost on pump gas is a large hotside on the turbo and strong intercooling. If I couldn't get away with 25 psi on 93 I would be concerned about my setup. Now how much power you make with that boost is another story. That's more about how much airflow you can move at that boost level. Airflow is power, boost is heat. A 2.3 with a 35R should be moving 55 lbs/min at 25 psi easily, which lines right up with the OP's 521 DJ WHP. Odds are that 35R also has a larger hotside for the 2.3, which only helps pump gas power and knock resistance (or probably avoidance, to be more accurate).
Old Mar 15, 2007, 05:17 PM
  #37
mjo
mjo's Avatar
Hi Derek,
Nice numbers. This is almost the exact setup I'm having done. it should be back in 2 weeks. I am also having Jackson Auto Machine do a Stage III 2.3l stroker. Did you allso get the Statge IV head? I also ordered the Shearer GT35R. I ordered the tial 44mm with the feed back into the downpipe. I was going to yave Sean Ivy due the tune on the AEM. I hope my numbers are as good as yours.
Old Mar 16, 2007, 11:42 PM
  #38
hybrids14's Avatar
Derek, congrats on the nice figures.
FYI, He's located in Taipei, Taiwan, where you can get 98 octane gas at every gas station. What he's claiming 93 octane gas is actually a 98 octane gas rated by Taiwan government but is more likely a degraded 93 octane gas or lower according the US standard. The 98 octane pump gas is so bad here I recommanded him to make sure he sprays meth and lower his compression. Race gas not available here..... life goes on......
Old Apr 10, 2007, 05:07 PM
  #39
hybrids14,
How much are *legal* s14 goes for in Taiwan? I plan to get one before the end of this year (in Taiwan). Do you have sources to get those type of cars? I don't care if it's automatic & KA, as long as the chasis is ok.
Old Apr 10, 2007, 05:19 PM
  #40
Recks's Avatar
I know someonehere in california running a 35R and is boosting 28-30lbs on 91! N like 30-35 on race gas
Old Apr 10, 2007, 05:28 PM
  #41
G20
G20's Avatar
Unless he has some kind of water/alcohol injection, he won't be running 28-30lbs on 91 for long.
Old Apr 10, 2007, 05:31 PM
  #42
Sean@Iveytune's Avatar
Very nice #s by the Taiwan service. The VPRO is god over there eh.
Sean
Old Apr 10, 2007, 06:20 PM
  #43
fusionchicken's Avatar
+5000 billion. where is all this bullsh*t coming from?
Old Apr 10, 2007, 08:13 PM
  #44
stunt1o1's Avatar
some good #'s buddy
Old Apr 10, 2007, 08:23 PM
  #45
scorke's Avatar
You quoted an incorrect quote and made just even less sense... In the intial post he states 26 psi on 93 octane, that is not in any way unimaginable, lots of tuners have IX's running around near that boost level.
Scorke
recompile
54
Jul 9, 2008 11:18 AM
Gsxtremedsm
For Sale - Cars For Sale
14
Jun 19, 2008 06:08 PM
OZR_Lancer
Jun 2, 2008 02:56 PM
xiaoni420
55
Nov 20, 2007 12:28 PM
Lucas English
41
Jun 11, 2007 01:24 PM
Quick Reply: Shearer 35R dyno results
