Syncro shot??? help please
hey guys, today I was driving and I started to get a grind as I went into 3rd. . Ive had a little bit of notchiness for awhile since I got the car but no grind. . but the grind got worse and worse, whether I shifted slow or fast or at a low or high rpm it grinds. (and grinds pretty bad) is my syncro shot for sure? Or is it possible that I just need to change my gear oil? Any help is much appreciated!!
How many miles on the car? Most people can solve notchiness issues with fluid changes, stiff engine mounts, and/or shifter bushings. Trans temp also has a huge effect on notchiness. Once grinding occurs, you need new synchros.
ya its a really bad grind that just developed today. I'm pretty sure im not under warrenty. . i have 53,000 miles. If theres a tsb out for the problem do you have to be under warrenty for them to cover it?
I just found out my powertrain covers me up til 60,000 miles!!
And I found a tsb for this problem: TSB-04-22-003 I have an appointment next thursday! One quick question, My car is lowered and I have a K&N drop in. . And also I'm not sure if I have the stock clutch or not because I am the second owner. . so my question is will the car being lowered and having a drop in have any effect on them covering my synchros under warrenty?
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
