Buschur 3065 turbo makes 473whp
#110
E85 would be the shiz if we could get it around the MKE area, I was 99% sure i was going to put alky on my car but Eric G is steering me away from it. Im not 100% sure on what i want anymore, i mean you guys only charge 500 for the kit so its not to expensive.... Any input? I'm going to see what i can do about getting race gas by the drums since my old man owns a Mobil station.
#111
The head is still stock besides the springs & retainers and cams yes. No porting, valve job, etc....
The block has never been out of the car. It is not o-ringed. We only o-ring the head. I just did the drop in pistons and rods in the car. I just wanted the upgraded safety thats why I switched the internals. The stock stuff was still working but just in case I didnt want a stock rod breaking and going through the block. Blocks are to expensive to just buy a new one.
I have run 30psi on my current setup with no issues. Our drop in Crower rods / JE Pistons, ARP headstuds, OEM headgasket, no o-ring, etc..... Shifting at 8500. Im not telling any of you to do that but thats just how I drive.
#113
Question for the original poster Bernardo...So in the video, the numbers you made were with just pump gas @ 21-23 psi? I ask this because posters are saying great job with pump/meth or pump/alk I would just like this clarified because I only intend on running straight pump, no meth/alk injection and if that's your case then I may just have to go with the 3065 setup. Thank again and great car.
#117
The car was making about 23psi on the dyno, but actually makes 25psi on the road because of the increased load. I'm still within a safe zone.
This turbo would be good on "only" 21-22psi on the road, but like Jarrod showed, any larger turbo is going to make dramatic increases in # on higher psi.
