transmission issues
transmission issues
have a 2005 8 mr, currently am locked out of 6th gear, and some gears only work when im at low rpms or stopped for example first only works when im stopped, 2nd and 4th work great 5 works when it wants to.. transmissions trashed anyone can shine some light on this it would help seeing that the dealership is already going to tell me if they are going to warranty it which i doubt
no, i was told that if it was adjusted wrong than the problems would have occured immediately after i starting driving it when the clutch was put in
Sorry to be the bearer of bad news, but you will probably have to replace the 5th and 6th gear or worse. You might have to replace the whole output shaft assembly because of the engagement issue with the other gears. But it is not related to the clutch install and you should not have to pay out of pocket. The problem with the 6th gear is possibly due to a 5th gear grind which distorts the gear and does not allow the sleeve to pass over to 6th gear way disallowing the gear to be engaged. (I think that it's called the sleeve)
Good luck with everything.
To the original poster: Try adjusting the clutch pedal engagement. Also try swapping in some fresh OEM 6 speed gear oil. If neither of these two things make a difference, you probably have a synchronizer problem, and need a rebuild.
RalliartMY10
Apr 28, 2024 10:30 AM
MagicManRed
596
Dec 9, 2020 07:59 AM
Braydo25
Lancer Troubleshooting
Aug 15, 2015 07:54 PM
john.schuber
Feb 26, 2009 04:48 AM
