Motor Problems car wont start
Old Mar 29, 2007, 09:06 PM
AutobonEvo's Avatar
I just installed my transfer case and everything went smoothly, i drove my car around for about 30 mins is drove smooth and fine i boosted it a little and it seemed strong. When i was driving it back to my apartment, i put it into third got on it a little bit (about up tp 4 grand) and i heard a pop sound and the car just died.
So i figured it was the intercooler piping that blew off cause is sound JUST like that. I got under the car and everything was super tight . So i started the car up again and it would idel like there was no MAF in the car, poping and makein weird noises and it would stall again. So i coasted to my apartment tried truning it over a few times and would idel really rough and pop and sound like a clunking noise from the head. I pulled the plugs and they look normal, looks like the gears are lined up like they should be.
im really confused as to what my issue could be. the car doesnt start now and i have a feeling that it could be bad this time. any insight is appreciated.
Old Mar 29, 2007, 09:23 PM
520hpsti's Avatar
sounds like a vacume line.
Old Mar 29, 2007, 09:50 PM
AutobonEvo's Avatar
then wheres the knocking sound coming from?
Old Mar 29, 2007, 10:15 PM
Luis@TTP's Avatar
do you have cams installed or recently installed a list of mods might help alittle
Old Mar 29, 2007, 10:49 PM
AutobonEvo's Avatar
cams were installed about a year ago, my mods are the usual turboback, fuel pump, intake, boost controler, cam gears, intercooler piping, and a tune.
Old Mar 30, 2007, 12:30 AM
Brian's Avatar
it still sounds like IC piping, did you check the couplers on the FMIC?
Old Mar 30, 2007, 06:00 AM
AutobonEvo's Avatar
i know i was really hoping it was them, but from what i checked last night they were all on tight. Ill check again but im 99 percent sure that they are on tight.
Old Mar 30, 2007, 07:49 AM
AutobonEvo's Avatar
Anybody else?
Old Mar 30, 2007, 09:32 AM
Brian's Avatar
Make sure your MAF hasn't come unplugged, your bov hasn't blown off the intake. .
Do you have a CEL, have you scanned it?
Old Mar 30, 2007, 09:51 AM
AutobonEvo's Avatar
MAF is plugged in good, i even unplugged and plugged it back in. The recirc valve is tight im going double check when i get home from work. Also i have a cat delete so i always have a CEL but im going to scan it today and see if it comes up with any codes.
The car did sit for the winter and i just pulled it out and it had low gas(just under a quarter tank) and the gas that was in there was about 6-7 months old (i did use fuel stabilizer when i put it away for the winter). Could that have anything to do with it?
Old Mar 30, 2007, 10:03 AM
Brian's Avatar
So if you start the car and give it gas does it stumble as soon as you give it gas?
Any chance that something could have been left in the intake tract if it was off and could have been ingested?
pull the filter check to see if the maf is OK. . .
Old Mar 30, 2007, 04:30 PM
AutobonEvo's Avatar
yeah whb u give it gas it stumbles then dies. i looked at the MAF it looked decent just a little dirty but ill double check. thanks so much for the ideas brian! keeep it coming
Old Mar 30, 2007, 06:08 PM
AutobonEvo's Avatar
pulled the valve cover everything looks good with the cams, rockers and lifters im stumped. Im goin to check the oil tomorrow along with a compersion check.
Old Mar 31, 2007, 04:24 AM
AutobonEvo's Avatar
bump
Old Mar 31, 2007, 04:48 AM
bigric09's Avatar
clear your CEL and see what happens
Quick Reply: Motor Problems car wont start
