Mobil 1 15-50
Mobil 1 15-50
http://www.mobil1.com/USA-English/Mo...1_15W-50_.aspx
I'm giving it a try. I think it might be a good idea for built motors and high boost. What do you think?
How bout Torco SR-1 synthetic. Claim up to 3% HP/TQ increase.
www.torcousa.com
www.torcousa.com
Have always run Mobil One and have so for many, many years on all my performance cars. I usually run 10-30 in the winter for alittle better cold start protection and 15-50 in the summer for driving hard under very hot conditions. Worked excellent for my mid 300 hp daily drivers I have had all the way to my built motor VR6 Turbo making BIG power. from me.
www.torcousa.com
www.torcousa.com
The heavier weight oil was made for better protection during extended runs. but the issue with these higher weights is how well they protect while cold. The thick cold oil has a hard time flowing between bearings and such when the motor has tight tolerances...when its hot its fine. When i was working with BMW motors the engineers told us that this it why they run such a low weight oil..thick oil wouldnt get around the motor like it should...(BMW motors have crazy tight tolerances)
My opinion if you chose to run this oil is always let the car warm up before driving so that the oil is at the right viscosity to properly protect the motor. Even in the summer.
i posted this in a thread earlier. I ONLY use Redline synth in my high HP engines. i have seen better spool, slightly more power(my own dyno testing) and much smoother revs. I also use Redline in everything else as well(i.e. diff, TC, transaxle....ect.) It's by far the best stuff on the market. You will pay dearly for it though....and it's sometimes tuff to come by due to the buy in vendors have to purchase to get the stuff....so most people don't carry it. Autozone use to carry it on the shelf, but since redline changed their order buy-in Autozone stopped carrying it altogether. From what i understand, the vendor has to buy a ton of product for each order....
Either way, if you can find a place that can get it......or are willing to order off the internet......make the switch to Redline.
CJ
CJ
Maybe some people should read some results from testing before assuming a higher priced oil is necessarily better: http://www.performanceoiltechnology....oiltesting.htm
Testing was done by Amsoil themselves and Mobil One, for being at the minimum, being half of the price of some of the oils mentioned did pretty damn good for a highly marketed, get at any auto parts store engine oil. But of course this is just my opinion and experience .
Thanks for the link. Looks like Mobil 1 does really well. 15-50 would do a little worse in some of those tests, but better in others. Since I live in SoCal and winter is over, I'm not too concerned with cold starts.
after reading mobil one website, it showed that their extended performance mobil one had the best base stocks compared to the rest of their line and also complies with the GF-4 mandate. That is why I started using it after noticing that my oem mobil 1 10W/30 was very dirty and thick at 4000 miles. With the mobil 1 10w/30 extended performance, I did not notice that.
https://www.evolutionm.net/forums/sh...d.php?t=251442
I am not trying to say one is the best and one is the right oil for everyone. I am just trying to say that if Mobil One is being compared to a oil that is almost double its price per quart and is competing very close to it then for the average weekend warrior that doesn't want to spend $50-60+ on oil every oil change it should be just fine .
