HOW MANY PEOPle OWN A EVO GREEN TURBO
#77
awesome, thank you very much. I was getting worried that we had a boost leak as it technically spools later than the stocker by a decent margin. At least I know all is well and I'm on the right track. What kind of timing numbers are you running in peak tq with meth? I think were running about 10 degrees...can't recall at the moment.
#78
#79
I own the green, just not installed yet. Getting some detail work done, and then the hotside is getting shipped out to get coated @ Swain Tech. Will be tuned on the XEDE, but I have a JDM 3 bar MAP sensor on order to go in place of the stock MDP sensor. When they finish writing the code to go speed density on the stock ECU, I think I will be switching over
https://www.evolutionm.net/forums/sh...10&postcount=2
#81
you guys think having vary little knowlege of working on cars that i could change my turbo to the fp green and clean out all the oil in my piping or is this not nessarary plz help im so newb
