Fuel Setup Needed for 2.3/35R
Old Apr 5, 2007, 05:25 PM
scorke's Avatar
What are you guys running for fuel delivery and what sort of duty cycles are you seeing on pump gas and race gas. I have 780s right now but feel I might be pushing them close to the edge on race gas, what do you reckon? Walboro too but everything else is stock.
Scorke
Old Apr 5, 2007, 05:31 PM
evo_08's Avatar
i have ams 1000hp fuel system and rc1200cc injectors.
Old Apr 5, 2007, 05:32 PM
dubbleugly01's Avatar
I'm seeing upper 80's for duty cycles on PTE 780's on a 50 trim, stock block and head, cammed, with AMS Vsr, Walbro, on pump gas with a/f's of low 11's. Redline set at 7800. I think you'll need bigger injectors at a minimum.
Old Apr 5, 2007, 05:34 PM
scorke's Avatar
What power/boost are you seeing those duty cycles at?
Scorke
Old Apr 5, 2007, 07:52 PM
8URVTEC's Avatar
IA Performance went with the recommendations of David Buschur. He recommended the dual pump system and an adjustable fuel pressure regulator. I have a 2.3L, Stage 3 head and GT35r. Before this was only a single Walbro 255lph and 1000cc PTE's it was running in the upper 90 duty cycle on 33psi of boost.
Old Apr 5, 2007, 08:17 PM
scorke's Avatar
Really upper 90s at 33 psi, what power were you putting down?
I am thinking 1000's are the way to go, I don't want to mess wit the duel pump, fpr maybe.
Scorke
Old Apr 5, 2007, 08:29 PM
Scorke
360 whp on a conservative DD, or about 410-420 whp on a dynojet. This was at 22#'s boost.
Old Apr 5, 2007, 08:48 PM
scorke's Avatar
Jesus i have made 490 480 on my 780s on topspeeds dynojet at 30 psi. I had room to go, im thinking 9 somethings.
Scorke
Old Apr 6, 2007, 06:01 AM
8URVTEC's Avatar
Scorke
563hp and 513ft/lbs on a Mustang Dyno, don't know what that is on a dynojet! WIth the new pumps, fpr and new clutch I think low 600's is possible.
Old Apr 6, 2007, 06:02 AM
CBRD's Avatar
im at 441whp on our mustang.... 850 cc's... im at about 70-82% IDC... depending on the rev range...
this is on pump gas... I also have 1000's in the cabinet, and will be going to the upgraded walbro for now (the modded one)
cb
Old Apr 6, 2007, 06:47 AM
Scorke
yeah, tell me about it. Either the DD is extremely consevative (overly consevative), or maybe my wideband was reading conervatively, or my system is whacked out. I did get another set of new 780's on the off chance the first set wasn't flowing properly. Same result...... upper 80's on duty cycle. I'm running about 47'# base fuel pressure to boot.
Per RC Engineerings injector calculator, it predicts my injectors almost perfectly at a bsfc of .65. But alot of people seem to make more hp on smaller injectors and lower duty cycle than my example.
I'm sure you've seen this, but here's a convenient link for others
http://www.rceng.com/technical.htm#WORKSHEET
Old Apr 6, 2007, 06:49 AM
scorke's Avatar
Yeah damn, sounds about consistent with what I ahve heard abotu 780s. I feel like 850-1000's will be a good comprimise for what I am looking to do, maybe 950's.
8urvtec sounds like your setup worked pretty damn well.
Scorke
Old Apr 6, 2007, 06:57 AM
8URVTEC's Avatar
Scorke, that is all before the twin pumps and fpr! The new stuff is suppose to be installed next week, we will see new numbers I am sure after they retune!!!!!
Old Apr 6, 2007, 06:58 AM
Spooldyou's Avatar
Scorke
i have 1000cc's in my car now, and its seems to be alittle overkill to be honest for pump gas. i think i over shot it with the that size, But, i think that i might be in the market in for a set of 880s... Im on the stock ECU.
If your running AEM the injector driver isnt as efficent, which might yield the need for a bigger injector, if your running the stock ECU too, then i would suggest 880s
Old Apr 6, 2007, 07:28 AM
Nesiop's Avatar
AEM or not I have heard from a few big time tuners the Injector driver box is a pos and is pointless.
Quick Reply: Fuel Setup Needed for 2.3/35R
