Fuel Cell Expansion/Replacement for Evo 9 SE
Hello, Im kinda new here and sorry if this doesnt belong, if it doesnt can you move it to where it does?
I want to add a fuel cell or make the current fuel cell bigger. I need the evo to go very far for a rally. Does anyone have any current specs on the fuel cell (dimensions, capacity, etc). I am looking to ideally get another one installed with a switch that would control if it was being used or not. Ideally I would not use it for normal driving conditions, but for a long trip or such, I could fill it up and get some really good range on the car. Please let me know what you guys think. Thanks.
When you say fuel cell i'm assuming you mean fuel cell, as in racing fuel cell as in tank with rubber bladder inside? I dunno about long trips, because you'll have to put it in the trunk, so there goes storage, but you could do it. As for rally purposes, is this a real rally, IE Roll cages required etc etc? If so you likely won't be allowed to use (or have) your stock fuel tank anyway...
Well, generally when you refer to a fuel cell what you mean is a box with a rubber bladder inside and foam to absorb impact so that in the event of a crash the bladder will distort rather than having fuel leak everywhere. The bladder also functions to prevent a lot of sloshing around of fuel to prevent starvation of the engine when you're running low. When you say road rally, do you mean like Targa Newfoundland? The Cannonball run? (If the latter, get a van and race that, I saw it in a movie once, works great )
If it's a sanctioned event, the sanctioning body should have some pretty well laid out rules regarding this.
You could mount a fuel cell in the trunk with a drain hose routed to the stock fuel tank. Top off the stock fuel tank, then fill the cell in the rear.
As you use up fuel, the stock tank will drain and fuel from the trunk tank will "refill" the stock tank. Once all the fuel in the trunk tank has drained, it will act just like having only the stock tank. Your fuel guage will work as normal, except it will stay on "full" for a long time (until the trunk tank is drained)
EVOlutionary
EVOlutionary
Probably would be better to put the largest possible fuel cell in the trunk with completely seperate wiring and plumbing up to a common t-fitting in the fuel line with an electromechanical switch. This switch would select which fuel line (from OEM tank or fuel cell) to allow to be connected with the OEM fuel line running to the engine bay. A network or relays could switch the respective fuel pump in the fuel cell on and at the same time switch the pump in the OEM tank off, and vice versa as needed.
thanks again for all the advice. Now to find people who would actually do this for me. Any ideas?
Once again, sorry if this doesnt belong in the advanced section, im new here and didnt know where else it would fit. Didnt seem like a common question so I figured some of the advanced guys would know the technicals of how the fuel system or a new fuel system would work.
TrinaBabe
23
Feb 11, 2020 04:56 PM
EVO8LTW
Feb 20, 2008 05:56 PM
