CANT GET MY STOCK TURBO TO GO PAST 12.1 in 1/4 mile
Old Apr 18, 2007, 02:33 PM
sikrsix's Avatar
Dicth the HKS BOV, get an actuator, and change out your cams for more power. Cut a high 1.6 60ft And if you think your boost controller sucks.. Change that too
Old Apr 18, 2007, 02:34 PM
HKSevolutionNYC's Avatar
Originally Posted by DontRevMe
i would expect a higher trap with the mods you have. do you have a dyno sheet you can post?
search my name on here, i have it, it thread name is RETUNED BY SEAN IVEY
DontRevMe's Avatar
Originally Posted by DRFTKNGG
A FORGE turbo actuator will get rid of the boost taper.
unless ive been living under a rock..the factory turbo will taper no matter what you do. Id LOVE to be proven wrong on this however
Old Apr 18, 2007, 02:35 PM
Originally Posted by bluebyu36
what plugs do you have?what are they gaped at?
NGK BKR7E i think gapped at 28
what boost controller should i go with ? i see alot of people using the Hallman
Old Apr 18, 2007, 02:36 PM
sikrsix's Avatar
Thats what I run.. No complaints yet..
Old Apr 18, 2007, 02:37 PM
bluebyu36's Avatar
u should check your plugs .when the gaped opened up on my plugs i could not hold boost...
maybe go one step colder to,bpr8es
i used both boost controlers and i seen no diffrence..
Old Apr 18, 2007, 02:38 PM
sikrsix's Avatar
Also a stock turbo should be holding more than 22psi but dont expect to hold 30 till redline..
Old Apr 18, 2007, 04:12 PM
vortech_g35's Avatar
Hallman or Forge for MBC. You should get a boost actuator and you should be fine.
Old Apr 18, 2007, 04:28 PM
EVOGOD21's Avatar
work on your 60'
Old Apr 18, 2007, 04:48 PM
Originally Posted by EVOGOD21
work on your 60'
its already a 1.71 a 1.6 isnt gona make me do a 11.6 or 11.7 in the 1/4 mile, my mph is also low because my boost just drops.
Old Apr 18, 2007, 04:49 PM
i was thinking gettin the hallman MBC, the forge WGA and bov that recirculates.
Old Apr 18, 2007, 05:14 PM
Kevin Knight's Avatar
go with a 10.5 hotside or just go buy a forced performance green turbo
Old Apr 18, 2007, 06:18 PM
the car is an 05 so it has that hotside already, and i want the stock turbo to hit 11s if i go with a turbo im not doing something thats gona make me do mid 11s wen my turbo can do the job.
Old Apr 18, 2007, 06:24 PM
sleet's Avatar
If your going for drag racing why would you pick a cam setup 264/272?
Quick Reply: CANT GET MY STOCK TURBO TO GO PAST 12.1 in 1/4 mile
