Not holding boost?
Not holding boost?
This only happens in 4-6th gear, wen i shift casually into 4th 5th or 6th gear around 3000 rpms with no boost , as i go WOT and i hit about 15psi on my 3065 at around 4500 rpms my bov will release the boost. if i downshift into any gears so my rpms are higher, it will hold 22psi in all gears. i thought it was my greddy rs bov was just **** but now i have a tial and it still does this. wat do you think the problem is?
no brand new act 2600....wen Al was tuning it he thought the greddy just needed to be adjusted tighter but it was all the way down, but since the tial is doing it, i dont know? wen i first put the tial on i tested this out and it was fine but a couple days later it started again
Hmm...this is interesting. I would say the BOV is not the problem if it holds 22psi in the other gears. I mean the BOV doesnt know what gear you are in. Could it perhaps be a misfiring issue? Do you ever get a CEL or anything? I know when I started throwing my P0300 codes a while back the car was actually misfiring and for the breif period when the engine didnt get fuel it would do the same as letting off the gas, which is buck forward and blow off the compressed air. Not saying this is what is going on but if your clutch is new then this is a slight possibility.
JamesKrickeberg
Jul 4, 2011 02:36 PM
