'White Rabbit" turbo
Old Apr 19, 2007, 02:19 PM
turbodude's Avatar
Does anyone know about a turbo for an evo called a white rabbit? if so how much better are they than a stock evo IX turbo?
Old Apr 19, 2007, 02:23 PM
Kee1pride's Avatar
stay away from this garbage of a turbo
Old Apr 19, 2007, 02:27 PM
TeStUdO's Avatar
Its an outdated piece now. If you want something better than your stock IX but still a "stock like" turbo, get the new 20gLT or EvoGreen.....your choice of what you call it.
Old Apr 19, 2007, 02:30 PM
turbodude's Avatar
how much horsepower potential does the 20g have on stock internals?
Old Apr 19, 2007, 02:31 PM
the chosen one's Avatar
about 20whp gain over ur 9 turbo
Old Apr 19, 2007, 02:32 PM
Kee1pride's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=263541
theres the current record on it, on a customers car. not even the shop car.
guessing that is around 460-480whp on a dynojet.
Old Apr 19, 2007, 02:33 PM
Kee1pride's Avatar
much more than that. maybe you're thinking about pump gas whp?
Old Apr 19, 2007, 02:41 PM
Erik@MIL.SPEC's Avatar
This turbo is not a piece of garbage. It is better than the stock Evo 8 turbo. If you have an Evo 9, it is not worth it. If you have an '03-'05 Evo, it's a decent upgrade. Good autocross turbo.
Old Apr 19, 2007, 02:58 PM
turbodude's Avatar
this dude I know is running a white rabbit on his 8 with only cams and 30psi on 100 octane and puts down 458AWHP and 458AWTQ
Old Apr 19, 2007, 02:59 PM
turbodude's Avatar
And that was on a mustang dyno
Old Apr 19, 2007, 03:04 PM
whitey4d's Avatar
Calling a White Rabbit turbo a peice of trash is calling a 20g-5 a peice of trash. same compressor wheel.
Old Apr 19, 2007, 03:07 PM
KOEvo's Avatar
Stock internals have nothing to do with anything; the turbo has the same potential regardless of what is done inside a 4g63. ALSO the 20LT won't touch the limit of the stock internals; people have made well over 600 whp. And don't just call it a 20g because there is another turbo called that and you'll get confused.
You should use the SEARCH function available in this forum.
Old Apr 19, 2007, 03:09 PM
Duby's Avatar
on an uncorrected dyno jet . . . my assumption.
+1 on staying away from it though, espially if you have a 9, wait until you max out your stocker; it's a very efficient and streetable turbo capable of 400+whp on pump. Anyways if you're not going for higher than 460~500whp, stick with the 20G-lt or stocker IMO.
Old Apr 19, 2007, 03:10 PM
two threads that he just started---"white rabbit" - "evo green"
Old Apr 19, 2007, 03:12 PM
dsmfan95's Avatar
The White Rabbit uses a titanium compressor wheel for lighter weight and slightly quicker spool.
Quick Reply: 'White Rabbit" turbo
