Tial surge even with EMS?
Well I know all those threads say youre fine with VTA as long as you have EMS. Well I have autronic, and when in 5th gear, around 65-70mph; if i try to give it gas, it will studder, and buck sometimes. Then even theres times where I will WOT it from 65+ mph, and itll still studder and buck.
This is all surge, correct?
I am starting to think it is just the Tial BOV. I have a 9psi spring, and I am running on low boost with the 3065 turbo, only about 20psi because of a problem with the turbo kit.
My major engine mods are:
FP3065 Buschur turbo kit (coming off soon)
4g64 bottom end
Tial BOV w/ 9psi spring (possibly gonna change if i find this is the problem)
Autronic PnP EMS
So my orig question is, is it the Tial BOV that is at fault?
4g64 bottom end
Autronic PnP EMS
Also not to be "that guy" but I happen to have a 7psi spring that i can sell you lol. I used it for a day but since I DO NOT have EMS, the car drove like absolute crap. I have the 11psi spring in there and it drives OK now. Luckily, my brother has a Tial on his 1G DSM and he had a couple springs.
if your vacuum is 15, you need a 7 psi spring. its weird but the spring is rated by 1/2 the vacuum in inches of mercuruy. if your idling at 15 inches, then you need a 7 psi spring and it sounds like its not opening
On a side note.......
I've read that you can open the TiAL BOV housing and shim the 7-lb spring to increase the spring pressure to mimic the stiffer springs.
Can anybody verify this?
