Gear Box F*** Up.
Gear Box F*** Up.
Hi guys need technical help, here it goes, i have an evo9 simple mods just an exhaust system, simple, my clutch had to be replaced, it was slipping like crazy, but yet did not have an sort of problems shifting, the deal is, i went to my tuner here, and asked for a clutch replacement, decided to replace it to stock clutch, till i decide what is the perfect clutch for me, so guess what...... they installed it, and now i cant even put in reverse, but keep in mind that they reversed the car out of the workshop, he tolled me its from the alignment of the clutch pedal, they tried to re-align it and yet its still engaging and not engaging...... so to make it short he's saying that its a clutch selector "inside the gearbox", that has to be replaced........ what do u guys think, if i can select the gears it means all is good in the gear box..... don’t know any advice...
exactly what they did, it use to engage in the bigining, thats how they got the car out of the workshop on the road, then they re aligned the pedal again and it worked with them once out of 4 tries, then no more so its an on and off situation if you know what i mean....
ok guys, just went to check on the car now, all the gears are going in exept the reverse, i was tolled and please correct me if i am wrong, the 5th gear and reverse are both on the same selector?....., another qu, if the selector broke i would it slip out of place?....
Peage
Mitsubishi TC-SST Discussion
Jun 20, 2016 11:33 AM
undressesitself
Sep 9, 2012 08:48 PM
Rumblefish237
16
Sep 1, 2011 02:26 PM
