Shep Trans "Ultimate Ratio" Gear box Review
Old May 8, 2007, 10:52 PM
DynoFlash's Avatar
My new gear box is a Shep Trans "Ultimate Ratio" trans which was put together by Shep to utilize the best forward gears from the 2003 - 2006 Evo 8 and IX in one trans. With the use of longer 1st and 4th gears the selction of gear ratios is "ultimate."
I just put this sucker in this evening
You can note from the attached dat log that 1st gear pulls up to 53 mph at just over 10,000 rpms and when you shift to second the rpms are in a much better part of the power bacn than on the previous stock Evo 8 gears
Here is a data log of a 1 2 and 3rd gear pull
I am very impressed with Shep Trans and highly recomend this new gear box
Old May 8, 2007, 10:58 PM
ONRAILS's Avatar
I will be intrested to see if you gain any mph from the gear change.
I guess this was needed because you were already running so high through the traps in 4th.. You needed the longer gear..
Al you are on the 4.11 final drive also right?
Old May 9, 2007, 01:01 AM
RickU's Avatar
Hey Al, would you recommend the 'Ultimate Transmission' with someone with 400whp?
Old May 9, 2007, 01:53 AM
Paul Nelson's Avatar
Old May 9, 2007, 06:58 AM
DynoFlash's Avatar
The ultimate ratio is for ANY EVO even one with stock power
It makes the speeds and rpms at each gear change point more consistant and better matched to our cars
I wanted to add that the prep and finish on this shep trans was better than new. Its really an amazing unit and it shifts like a dream right out of the box!
DynoFlash's Avatar
I am on stock final drive
I am doing some other things to the car - may make it out to the track tomorrow or next week
AL
Old May 9, 2007, 07:00 AM
cij911's Avatar
Very interesting Al....When I first got my MR, I felt the gear ratios could have been a bit better and wanted different options...Glad Shep is going this route...
Old May 9, 2007, 07:14 AM
EvolutionBoy67's Avatar
Al would you recommend the HKS 4.11 Final Drive with the new Shep Ultimate Ratio Transmission?
BlackEvo08 (May 26, 2022)
Old May 9, 2007, 08:21 AM
DynoFlash's Avatar
I have no idea what to recoemnd about final drive
Shep is the man - give him a call
Old May 9, 2007, 08:22 AM
What is the cost on that Badboy Al?
Old May 9, 2007, 04:43 PM
Frenchy4g63's Avatar
So is this just for straight line guys?
Or are there benefits for road racing/autocross guys?
Old May 9, 2007, 09:41 PM
Tsurugi-san's Avatar
Curious as well ---- is this an ideal straight line setup, or are the new ratios equally as tractable in the twisties?
Also --- other than a swap from the 6 to the 5 speed, is there a similar upgrade path for the 6 speed tranny?
Thanks!
Old May 9, 2007, 09:55 PM
If Al doesn't respond, I e-mailed Shep about this, and will post his response as soon as I get a reply.
Old May 10, 2007, 12:14 AM
cetinsaya's Avatar
hey guys,
I dont like my IX tranny and gear ratios... what is your advices?
like small modifications...???
Old May 10, 2007, 03:24 AM
ONRAILS's Avatar
4.11 Final Drive would make for taller gears right? Load the car better in 1st and 2nd for be big big turbo guys. Making the gears not so pointless and keeping you out of 5th for stroker guys through the traps.
That's the way i always understood it?
Quick Reply: Shep Trans "Ultimate Ratio" Gear box Review
