clutch replacement (to use stock flywheel???)
I will be purchasing a clutch kit soon for my evo. It is starting to slip a little on heavy loads 4th & 5th gear.
My question is should I get the flywheel resurfaced, buy a new stock flywheel, or a aftermarket flywheel?
Thanks for any ideas, or professional experience.
It would slip in 5th before it would start to slip in 1st. If your car slips in 1,2,3 then its prettty shot. I've heard not resurfacing it since it thins it out.
I think I remember somewhere just clean it off with a scotchbrite pad and replace. I am prob wrong tho. .haha Any other insight?
Resurfacing would be the most economical and effective means of keeping your idle stock like (you might hear chatter with a lighter flywheel). All they do is lightly sand the surface so that it is even, clean it down with a solvent so the surface is clean and true in order for your clutch to mate up perfectly. . .
I went to to disk already with no problem. The first time I just put in the ACT kit. No chatter nothing and the stock clutch was slipping. The second time I got the flywheel resufaced while it was at the stealership, getting the tranny fixed. I just put in an ACT disk and that was that. No problem, Now I think I will get a exedy twin disk.
I have the Gruppe-S lightweight flywheel and on occasion my car idles funny, almost as though it wants to die out. This only started happening after the flywheel install.
(No I don't have a VTA BOV, no intake, No cams)
It's not bad though, and once I get my cams installed and re-tuned it should be fine.....
How much miles you got? Im right at 30k and never really abused my car, maybe launched it 5 or 6 times and my clutch is almost gone. Slips crazy in 4th and 5th on the highway, barely driveable. Thought the stocker would last me longer then that
thanks for the info guys.
I have heard the same thing that if the flywheel is good scrubing it off and cleaning it is all you need to do.
I just didn't know if I wanted to spend the extra money on a new or aftermarket flywheel, but I don't wanna be pulling the transmission after another 15K because I didn't do it right the first time.
Find a perfectly straight piece of metal and lay it on the flywheel's surface that the disc rides on and see if it is flat. If it is flat and smooth, leave it alone. If you can put anything more than a .010" feeler gauge between the straight edge and the inner portion of the surface, then you should get it resurfaced (...or replace with the appropriate ACT flywheel... ). Ask them about re-balancing the flywheel too because many shops won't balance the flywheel after resurfacing.
I've had aftermarket flywheels and stock ones, and for the loss of a few pounds in rotational inertia, I gained more head aches with chatter at idle, revs dropping down (making around town driving a pain), and burnt clutch discs (because you have to engage at higher rpms initially with a new flywheel AND clutch since they are both being bed in). . .
Dirk (ACTMAN) is completely correct in how one should measure residue on the flywheel after it's been resurfaced AND balanced. . .
and to give a free bump to a great company, consider the ACT clutch with street disc, I've had it for 6 months now and have only had amazing results with little extra pedal effort (and holding power to about 400+lbs torque, which I'll never hit on my stock car )
