Any1 having issues with Exedy clutch?
Does anyone have any issues with the Exedy Stage 2 clutch for the Evo? In first gear it shakes the car alot when i ease out of it, then it whines also. When i down shift it whines too. Anyone having similar issues on these clutches and is it supposed to do that?
if you are talkin about the single organic clutch...yes i had the same issue..although i had a brand new exedy flywheel/clutch/clutch lines...
it did this for the first 700miles...it took me alot of pedal adjustment...ultimately went away when i made the clutch engage as soon as you release the clutch pedal..then i was experiencing high rpm/quick shift gear lock out....it took some more adjusting until i found a spot where it doesnt vibrate/lock out...but the vibration went after a proper break in...you need the patience dont panic.
ps my friend also experienced the same thing with the ralliart stage 3 clutch...it also went after break in...
hope this helps...
good luck and keep us posted.
Respect
Moose
hope this helps...
Respect
Moose
