Throwing codes after putting stock ECU back in...
Hello all,
I need some help here, I'm due for inspection in a 2-3 weeks, so today I swapped out my AEM EMS and put the stock ECU in. I put the MAF back in and disconnected the AEM AIT, but plugged in the MAF plug.
I undid the wiring to the 5-Bar map sensor and ran the wires like stock to the stock MAP sensor.
I also swapped in the stock injectors.
so with everything done, I started up the motor and let it run for a few minutes and guess what I'm throwing 6 codes:
p0113- IAT sensor 1 circuit high input
p0102- maf or vaf a circuit low input
p2229- Barometric pressure circuit high
p0243- turbo/sup wastegate solenoid a malfunction
p0106- map/baro ckt range/perf
Can anyone help me to resolve this? I do recall that I have to go out and drive for like 100 miles or so before going for inspection, but this is really discouraging....
Just an update, I found my stock Boost control solenoid and plugged it back in....
I also took off the mAF plug and plugged it back in also.....
now I'm only down to two codes....
Stop unplugging the damn MAF with the key in the on position.
I disconnected the meth input wire to the ECU harness and soldered everything back together thinking it would solve my problem with the last 2 codes, but wrong....
These 3 codes still remain....
I did..... struggled with it for a long time tonight soldering everything together....
There was only 1 wire from the ECU harness that was tapped, the red wire with the white stripe was cut, with the end going into the ECU tapped to the meth....
Nothing else is cut or tapped
I disconnected the battery for like 3 minutes, hooked it back up.....
started the car, car starts fine, and starts quick, but it idles like crap at like 700-800 RPM's, bear in mind I have HKS 280's in there with the intake cams set at +2. exhaust at 0
I show the codes no matter what, and when I try to clear the codes with my OBD2 scanner the codes just comes back on....
The MAF wires have not been reconnected correctly. Check them again.
If you have a SAFC, wire it in also and check the MAF signal on the SAFC display to verify it shows a signal.
