Forced Performance Turbo
I've have been looking at lots of different options lately and mainly I want an extremely responsive turbo for my evo 8 but I still want to put down some solid power numbers. I dont really race 1/4 mile that often but I really enjoy autocross.
I am thinking I will prob get this turbo from forced performance...
does anyone have any experience with it?
also if anyone has any other turbo they would like to recommend I'm all ears I have also thought about a 16g or a gt40.
here is the forced performance one:
http://store.forcedperformance.net/m...e=Lancer-Turbo
Edit: I know this is a fairly common turbo but everything I found when I searched just talked about the dyno numbers.. I was hoping to hear a little more about its drivability and how it was for autocross.
Man there are too many threads stating that the turbo spools like stock so therefore the driveability is like stock + 40 - 60 hp extra and more topend kill, which normally is a good indicator that it is a great autocross turbo. GT40 will definetly not get you good autocross numbers, but if you gonna run the texas mile then have at it.
This turbo does not spool like stock. It has more lag... but not much.
If you have an Evo VIII then you already have a 16G
Be prepared to do injectors if you do this turbo.
It is a great road racing turbo and I have been very happy with it as a daily driver.
What a rediculous thread; this has the be a joke.
TONS of people run the FP-green, and you will have no problem finding all the information you need by running a quick search... It would be perfect for auto-x as it pretty much out-paces the 50-trim and gt30r at their own game; of which would have been your choices before its' inception.
Your stock Evo already has a big 16g, you can't do any better; And i have NO IDEA how the gt40r got thrown into this, that is one of the laggiest, most powerful turbos out there, it would be horrible for auto-x... Plus the gt40r has been proven to not like the Evo platform much, most people go straight from gt37r to the gt42r.
You have a lot of time to spend on this here forum, i suggest you quit creating pointless threads and get to it.
My bad I should have been more specific the 16g I was referring to is a big 16g that someone is selling locally that was sent to forced performance which is being sold pretty cheap(sold the car). and the gt40 was recommended to me by someone else but I think they may have meant the 30r
The stock turbo is a "big 16G." I think you better do some reading and research, youre mixing things up really bad and you sound like you have no clue about what you are referring to.
This turbo is externally the same as a stock EVO9 turbo, it uses the larger diameter EVO9 compressor housing and bearing housing found in the 2006 models. It uses our 700cfm 69-5 billet compressor wheel and our enlarged 11 blade turbine wheel. This combination of increased compressor and turbine flow results in a very broad powerband and stock like boost response while still being capable of well over 400whp.
True I have over 200 posts but I wish it showed when the last time I posted was.. up until last summer I was on here all the time learning and much as I could about my car and modifying it. then back in august I had a very unexpected financial crisis so my car became just a mode of transportation that I couldnt afford to have anything go wrong with so I just stayed off the forums because it would just get me depressed that i couldnt buy anything.. finally I have paid off my previous expenses and found a new job so I can get back into it.. So after about 9 months of not thinking about my car at all is the reason my memory for every part for the car isnt as sharp as it once was
No **** it has more lag, but it spools like stock, I didnt say identical to stock or just like stock. Here ya go right off the forced performance website homeboy
^^^ What he said. My VIII turbo kicked in like a sledgehammer.
There is approx. 900rpm difference on my dyno sheets where the VIII and the green hit peak TQ; the green being slower of course.
Now I do admit that we found a horribly leaky BOV after that and corrected it, and the green does come in quicker, but still not like my VIII.
To the OP, if you want to autocross, then fast response is going to be more important than overall HP. Getting off the apex is everthing in autocross.
You'd be better off looking for a TME or similar.
I've got FP's White Rabbit, which is from my understanding a stock 05 Evo 16g with the 10.5 hotside that has been ported and has lighter internals. It spools very quick and seems to make good power acoording to the butt dyno. Not sure if this helps.
