Kelford IX Cams
Old Jul 22, 2008, 04:23 AM
  #31
SLOWRREX's Avatar
What were the supporting mods on the 370 hp?I am coming to have some work done by you guys in a few months when i get back.At TTP that is..Just wondering what other mods the car had..Thanks..Justin
Old Jul 22, 2008, 07:03 AM
  #32
4kinboost's Avatar
Originally Posted by Wicked E
Going to throw a curve ball and ask about where the Cossie 272's rank in with these 3 bad boys...
Tom, I too have done some research and your findings are identical with what I am finding as well. Depending on what is said about my question above, I may be switching over to the FP4R. I am going green on the SE with an AEM, so I have been watching you and your son like hawks lately...
-E
+1 on the Cossie 272's.
I'm on these cams as well with stock springs. I find that my boost 'bleeds down' after 7300rpm about 5psi on every log. I'm wondering if valve float is the issue here. According to all of you cam experts, can springs be the cause of this.
If that's the case, I may just swap the cams for better units while I'm at it.
Anyone prefer these Kelfords or BR272's over a pair of Cossie 272's on a stock motor, AEM EMS, 35r car?
Old Jul 24, 2008, 02:37 PM
  #33
EvolvedGTI's Avatar
This is weird.
I asked: Question: Do the camshafts require a valve train upgrade?
They replied: Jonathan.If you are using more than the stock RPM and more than 21lb boost, werecommend a valve spring upgrade. Either Supertech dual springs or Kiggleybeehive or Ferrea beehive springs are the best option. ThanksKevin
What gets me is the more than 21psi, most everybody not stock probably runs over 21psi.
Originally Posted by S2kracka
I just heard back from Kelford:
Hi Chris,
The 272 is the right choice to get the most out of the stock turbo.
Yes, these will run on the stock spring and retainer, your rpm will be
restricted by the turbo well before it is restricted by the valve spring.
Thanks
Kevin
Old Jul 24, 2008, 05:29 PM
  #34
Ebirns99's Avatar
I've actually just had the kelford 272's put into my car by AMS I'm pretty happy with them so far, lost a little on the bottom end, but gain a lot on the top end
Old Jul 27, 2008, 11:24 PM
  #35
Steveevo9's Avatar
Have you got a dyno graph that can show how much of a loss you had in the bottom end at all? Thanks mate.
Cheers Steve
Old Jul 28, 2008, 06:23 PM
  #36
daisaw1219's Avatar
what about the HKS 272's for mivec
Old Jul 28, 2008, 07:04 PM
  #37
Davethewave's Avatar
do a search for AMS cam shootout, the kelfords won, hands down better than anything else out there.
Old Jul 30, 2008, 01:53 AM
  #38
808boost's Avatar
good thread!!
Old Jul 30, 2008, 07:14 AM
  #39
Sluggo's Avatar
If I'm not mistaken, that test was done exclusively with an Evo 8, therefor the results do not apply to us except to say that kelford makes good cams in general . As far as their mivec cams, I haven't seen a ton of data, but it seems promising.
04Evo851374
Oct 24, 2015 05:28 PM
evoLuzN
29
Oct 1, 2014 08:17 AM
inco9nito99
Nov 2, 2008 12:06 PM
Evo818
12
Jan 26, 2008 06:04 PM
tbizzy85
Jun 29, 2005 04:19 PM
Quick Reply: Kelford IX Cams
