RMR or WORKS reflash?? Anyone install yet?
#121
Originally posted by Eric Lyublinsky [/i]
[B]What I really trying to state is if you were to upgrade you exhaust system there is now loss by going to 3in. So if you ware inching for more power replacing the elbo is a option for you. I think the EVO even with the stock cams and proper EM on street gas is able to get to that magic 350hp mark on the stock fuel system and turbo. As far as IC I'm not sure it will make much more then 290 to 300 whp on a dyno jet. The stock turbo just blows to much hot air at thoes power levels. HKS's 2.5 is just not ideal.
Eric
Eric
#122
A 3.0 is a must for big boost power. It will elimitae creep, that is for sure, and I plan to run a 3.0 dump off my turbo so I may need to to control the creep, how much is that 02 housing????
#123
Originally posted by Alfriedesq Check your facts = I have a Gt 3037 S kit on my desy - the o2 housing / dom pipe with dump tube - is ONLY 2.6Inches - not 3"
![Mitsubishi Logo](https://www.evolutionm.net/forums/images/smilies/mitsu_logo.gif)
#124
Originally posted by evo1
Al, I was referring to the larger HKS turbo kit ... GT 3240. Dom pipe with dump tube is 3". Still very surprising that HKS does not recommend a 3" dp with the 3037 kit. How much bigger is this turbo over stock
16G? How much bigger than
20G?
![Spinning Smile](https://www.evolutionm.net/forums/images/smilies/spin.gif)
#125
Comes down to cost why have another down pipe when you still can use the 2.5 the have already sold you. Mind blowing??
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
![Dunno](https://www.evolutionm.net/forums/images/smilies/dunno.gif)
#127
Well, when I complete my ECU mod, I should be running right around 300whp. If I can find a good, inexpensive 3" high flow cat out there ... maybe I'll try to compare a 3" dp + 3" o2 housing to my current set-up (2.5" dp + stock o2 housing) ... you win Eric, r u happy?
Hmmmm ... I wonder if AMS will offering a high flow cat?
Not interested in test pipes (running catless) anymore. I believe Vishnu and/or RMR may have one avail as well.
I'm always happy and more so today then most. I'm might have a brand new EVO in my gorage as early as saturday if this dealer I'm dealing with will give me the trade in I'm looking for. And it is never about winning. I have seen so many set ups on the dyno and 3in always out flows 2.5. On the wrx with a larger turbo VF30 slightly smaller then a 16g with a 2.5 cat less exhaust has boost issues because of the 2.5in back presure.
Just going by what I see.
