Starter replacement
Old Jun 5, 2007 | 08:28 AM
rob_d's Avatar
Starter replacement
I'm going to be replacing the starter on my 03 EVO. I checked the How To pages and didn't find anything on this and I wanted to know if there is anything special to do other than unbolt it and bolt up the new one.
Any alignment tools, shims, or anything else needed?
Any tips?
Thanks in advance for any help.
Old Aug 31, 2008 | 06:59 PM
cheb evo's Avatar
bump. I am in the same boat
Old Sep 15, 2008 | 07:48 AM
assaultman2004's Avatar
Same problem hear too. My starter sounds like it's spinning but does not catch onto the flywheel. I have to quickly turn the key fast about half a second increments before it starts.
Old Sep 15, 2008 | 09:16 PM
BerserkerX's Avatar
Just replaced mine. No you do not have to line anything up or do anything special. I would reccomend of course taking your positive side off of your battery before changing it though. I did and then after that the car fired right up so it should have no issues.
Old Sep 15, 2008 | 10:23 PM
ant_turbo's Avatar
very easy!! I think there is 2 or 3 bolts starter to engine block,,and then 1 or 2 wires that are on the starter ground power....I replaced mine 20min job,,,
Old Sep 16, 2008 | 04:43 AM
Aman's Avatar
their are no shims or anything , 20 min job
Old Sep 16, 2008 | 04:50 AM
fugiwara's Avatar
20 mins job? no way, starter is not as easy reach as the battery...
I am curious on how many miles do you all have that needed starter change? starter should last a long time.
Old Jan 10, 2009 | 11:45 AM
migs647's Avatar
EvoM Community Team
I'm changing mine today, 58k miles.
Old Jan 10, 2009 | 12:10 PM
robogast's Avatar
The starter is prolly the easiest thing IMO. If you go from underneath the car, it is right there and there are 2 bolts that screw in oppsite directions( one screws into trans and one screws into starter). There are two wires. One has a nut on it and the other is just clipped on. Easy day.
Old Jan 10, 2009 | 02:31 PM
migs647's Avatar
EvoM Community Team
Yah I was scared the bolt from the opposite direction had a nut on the end. I was thinking how the hell was I gonna get that off! But yah came right out. I did remove the tray off of the starter to get to the positive easier though. Worked great!
Old Jan 10, 2009 | 04:10 PM
DG Motors's Avatar
1. dis-connect battery
2. If you have an undertray, take it off.
3. dis-connect power supply to starter first.( 12mm nut/washer)
4. dis-connect ground supply( This wire has a connection, you can just pull it off)
5. remove 2 14mm bolts that run through starter. There is one on either side.
That should sum it up. Removing the undertray should take the longest by far.
Old Jan 10, 2009 | 04:22 PM
4G63 T's Avatar
How much did you pay for part?
shrtstuff89
May 6, 2021 02:41 PM
broke06RS
Nov 19, 2015 08:16 AM
Rayne
Mar 24, 2012 03:09 AM
Charlie-Y
Dec 30, 2010 05:50 PM
Quick Reply: Starter replacement
