what's the + & - of the 6 speed MR trans?
i don't know, i tried some redline for a few hundred miles and it shifted like crap. noticeably worse than the stock fluid. then i researched a bit and found this, and it shifts better than the oem fluid, especially when it's cold, never grinds. i do race some, just not road race, so no exteme heat yet. but i still think this fluid could be a + to use in the 6-speed due to what oems use it for and that it's an exact equivilent to the super-multi gear.
i went through two in a row on factory fluids at trackdays(road racing - not 1/4mile stuff). this was on a mild tune(275whp). both were warped 3/4 sliders. first one died during my second session at t-hill.
we thought it might have been due to low mileage and possibly not being fully broken in(around 1K miles). had it rebuilt and reinstalled. ran it for 3k just to make sure it had some miles in it then ran it at laguna. the second one started going out in the last session. that was it, had it rebuilt and then bought a shep 5-speed and did the swap.
there are quite a few people that run 6-speeds at the track with no problems so you might be just fine, but for me it didn't work out so well.
i just don't get why people don't understand in the owners manual it says to use the factory fill or an EXACT EQUIVILENT ONLY. this is the only time it says exact equivilent for any drivetrain part, the 6-speed. and it's probrably not a coincidence that the ones breaking are most often running non-oem or exact equivilent fluids. no where have i seen a redline product period that is 75-85 GL-4.
Because most people failed to read their owner's manual.
Come on people, read that sheite. It might even keep you out of trouble.
Got a 6 speed? It's rated for only 290ft.lbs of torque. Use the factory recommended oil.
Jon@TRE
I don't need to defend myself against you I was just offering some advice that this guy ask for.
The 6 speed is great unless you make more than 450 whp. They are not as strong. I have a 2006 MR with 6000 miles on it and the tranny just went out. I never even got it to the track. The trans is fine for most cars. If you are going to do the basic mods it will be fine.
How about from ppl who race and test Evo's almost daily. http://www.competitionassociates.com/.
Theres a 30 page thread on what fluid to use in the 6 speed to keep heat down. Search. Heat is the enemy of gears 4-6. Plain and simple. You need a THIN (read that Kodiak? Not a shockproof) fluid that protects from heat well. There is a reason why the six speed uses a different fluid then the 5 speed does. Its a bit thinner. Use an exact equivalent or super diaqueen ONLY.
hondafan - i tried the Syntorq LT as recommended by Altavlet (sp).. I didnt like the shifting quality so I went back to oem Diaqueen.
94AWDCoupe - my tranny has been draining clean but when I drain my TC its always black as night... I fill that sucker full too and check it many times before calling it good. The TC sounds very good, ie - doesnt sound like my 03 did, so I was wondering if your rule of thumb goes for the TC too..
