Evo Green Dyno Sheet on 05 Evo with minimal mods
#61
Al so if I didnt want to run meth/alcy/race gas what would be the better choice in Turbo's? The 20g IX turbo like gruppe-S sells? I had planned on going to a green but now I am not so sure. I have:
DC Downpipe w/ decat
Magnaflow CBE
Buschur intake
Buschur ported stock o2
Helix 272 cams
Injen LICP
255lph FP
Sorry if anyone thinks this is off topic.
Magnaflow CBE
Buschur intake
Helix 272 cams
Injen LICP
255lph FP
Also, your mod list says "ported stock 02". I wouldnt waste money on that either. The SS 02 housing Buschur sells or the infamous "Ebay 02s" make much more power and are inexpensive.
#65
If youre going to run JUST pump gas and 22-23psi, the stock turbo will be the best option for you. Spending $1000+ on 20G based turbos to run straight pump gas and low boost is a complete waste of money.
#69
I dont like to see my customers with a stage I or II car come to a dyno appointment with one of these greens and a set of 680 injectors they dont need and get the same power levels as a car with a stock turbo and injectors
Al
#70
This was about six months ago. The car makes more power now with better tuning and small changes.
Very minimum lag, almost does not exist.
To aid with the lag, I got a very nice ported job done on the E. Manifold, ported Turbo, up-graded actuator, the Forge RS BOV, and Injen intake, pipes, lower and upper, and 02 Housing. The Boost controller, E0-1 also helps with the spool as it controls gain and waste gate, and it is set by rpms with an increased duty cycle at 3800 rpms and 4100 rpms.
Not everyone is going to have this results, as the parts in each car may be different.
#73
Riddle me this....what was the purpose of the Green upgrade? If its your daily driver and you happend to run at 30psi 24/7 then I'm sure the on-ramp for your commute to work is a flipping blast, but very few people would drop that kind of ching for no real purpose.
I would say the dyno is impressive for a "stock appearing turbo" but I wouldn't consider that car a street dominator. I understand the sleeper approach on some cars but on an evo? The green is a poor choice for drag turbo. Could have maintained stock spool and added a 50-100 shot of juice for $500. Don't like nitrous then like Al said a 35R could get you big power without all the fuss.
Even though Razorlab has provided a dyno showing next to no increased lag (thanks!) I still can't say that the Green would help at an autocross as most of that power would be unusable. Also keep in mind not only does your WOT tune need to be dialed in but the partial throttle and transitional tune better be dead on the nuts as well. Thats looking at RAW time only as I think the mod would kill your PAX.
This leaves us with open track stuff. The major benefits of the green come from race gas, bleeding edge tune, and high boost. This doesn't sound like an open track receipt to me. Most of the EVO guys I see at lapping days run 23psi with meth/alchy for safety. How does a Green compare to a stock Nine hair dryer at 23psi with octane/meth/alchy? I don't know the answer to that but since we're are talking about safety.... before selecting a green to decrease lap times a person would have to have an even longer list of supporting mods. The shop cars, the sponsored drives, the Richy Rich guys, they could probably pull it off but most of the green customers aren't out there upgrading brakes, tires, and driver skill to match the newly adder power.
This will be my last lengthly post on the subject. I'll agree that a 400whp EVO would be more fun to drive to work. And when the car is in full race trim, you may even be able to win 5% more races. The "on the surface" cost appears to be low but the attainable gains have to be earned via fine tuning and supporting mods. This is gonna cost you one way or another.
Its your time and money.
#75
Some more data for you.
This was my stock 05 10.5 turbo at 26psi peak on 100 octane:
This is my FPgreen at 26psi peak on 100 octane:
This is my FPgreen at 24psi on 100 octane:
This is my FPgreen at 22psi on 100 octane: (please ignore the beginning of the torque curve on this one as it was a incomplete tune at the time because of time restraints), this is my open track tune
As you can see, with the FPgreen @ 22psi, I am running more horsepower with 4 psi less than my stock turbo did, and with a much better top end. Also keep in mind my open track tune has alot less torque, this was tuned for as I have a 6spd and wanted to put less stress on it at the track.
I consider all these FPgreen tunes more normal world tunes, and not 33psi C16 bonzai 1/4 mile tunes. My personal car could make more power with this turbo but it is currently set up for faster spool and boost response than all out power. Still have stock 02 housing and +1/-1 cam gear settings which make the car very very responsive but I am sure I am giving up a healthy amount of power up top.
