What psi should the stock diverter valve hold?
I'm trying to diagnose a problem with my diverter valve but not getting much feedback here: https://www.evolutionm.net/forums/sh...d.php?t=276307
So here are two specific questions:
- What psi should the stock diverter valve (the IX metal one) hold with no positive pressure input into the vacuum nipple
- What psi should it hold if I provide positive pressure into the vacuum nipple.
I am suspecting that my diverter valve broke as I can't even to get it to hold 1 psi with the vacuum nipple at atmospheric pressure. My guess is that is should hold around 6psi....no?
(I'm trying to test my valve similar to as what is described here: http://dv.mistertam.com/)
Thanks.
Thanks.
This is a good question and I'd like to know the answer as well. The example of the metal DV I had on my car was already venting noticeably at 10-11 PSI. The spring itself is pretty weak and I'd guess that it's starting to lift as early as 7#. This is just a guess though as I've tinkered around with mine somewhat and eventually crushed it and finally tossed it into the trash bin.
I too would like to know if anyone has measured at what PSI the valve cracks off its seat. Incidentally, what sort of device do you use to measure this?
All you need is a pump and a bike tube... browse this link for pics and testing instructions: http://dv.mistertam.com/
Ok, I build a little test rig, same PSI input to vacuum nipple now as the valve. See pic.
It does not hold pressure too well. If I pump up to ~25-20 psi, air leaks out almost as fast as I put it in. I assume that it should be able to hold 20 psi without issues for at least a few secs. At ~15-10 psi, the leaking is slower, but it eventually all leaks out within ~10 secs.
Can anyone repeat this test with a good valve and post your results?
This seems to be consistent with my car's behavior. I guess I'll have to buy a new valve... can't be bothered with dealing with warranty, too much aggravation from past experiences...
Ive done the same thing a while back , my tester looked very similar .
From what ive found . The plastic 8 bov leaked @12-13psi , The IX bov leaked @24-25 psi and I also tested a HKS SSQV and it held to over 40psi .
The make sure I was hearing the leaks I put the BOV under water land looked for the bubbles . The IX BOV leaked very little @24-25 psi but i saw some bubbles , 26-27 psi was a lot of bubbles .
Sounds like your IX bov is not working like the one I tested , just for fun try the same test but put the hose from the tester on the discharge side of the BOV and retest . IT should NOT LEAK at all , if it does leak it prob more of a the piston (of the BOV) not sealing . If thats the case check for dirt where the piston seals to the valve body .
Chris@nolimitmotors
447
Dec 26, 2018 04:09 PM
itsdecker
13
Oct 1, 2016 07:14 PM
xtnct
12
Jun 14, 2007 08:21 PM
