How to tell if you have cams?
easiest way is to take off valve cover(10-15mins) and check for a company name..i know HKS has "HKS' on there cams...not sure about everyone else...
or if you dont have a tune then the idle will be rough depending on company/grind
you should be able to see the hole as circled in step #18 in the evomoto.com install guide. if you have a vac of 19 you have stock cams. stock cams do give a slightly lumpy idle
Smurf Rocket
24
Oct 22, 2010 06:00 AM
MRevolutionRed
19
Apr 19, 2007 07:55 AM
dubbleugly01
GSC Motorsports - Charleston, SC
Nov 3, 2006 05:05 PM
