Clutch Replacement
Clutch Replacement
For people that have replaced thier clutch already....could I get your feedback on what aftermarket one you selected....9000 miles and mine is biting right at the top....no drag style launches and no abuse has ever been given to this clutch...it must be made of recycled Bounty kitchen roll...I am annoyed that the standard clutch is shot already...other cars I have owned have lasted at least 60,000 miles
On my Subaru I installed a Clutch Masters stage III single plate clutch that was made of Kevlar. I liked the way it engaged very much, plus they are suppossed to last like 5 times longer than a regular clutch. I'm not sure if they make that disc for the EVO but I'm gonna find out...
Clutchmasters and Exedy are made by the same company I do believe. Daikin-clutch has their name proudly stamped on my CM Stage IV pressure plate. Exedy has a bigger line of clutches (esp. multi plates) last I checked though.
You definately don't want a Kevlar disk on a street driven car....it does not do a good job of expelling heat.
We have the Exedy single disks available right now for immediate delivery, twin disks are on backorder till July right now.
While Clutchmasters and Daiken have parts in common, they most certainly are not the same AFAIK....almost every aftermarket clutch company out there uses some part from Daiken, as Daiken is far and away the largest Japanese OEM and aftermarket clutch firm in the world.
Adam
Adam
This is the first time I feel I have to question your advise... after having experience with Kevlar on street cars (one very high power and heavy AWD) how do you come to this conclusion?(the street driven car part) We liked the fact that the disk had a little slip prior to "lock up". I was looking for a unsprung kevlar disk with not too damn a heavy pressure plate for street use...
I used one on my Subaru a few years back, and it was a horrible experience. Under load it was fine, but as soon as the car sat in traffic for more than 5 minutes, or after doing a single launch, the disk would literally just soak up the heat, and you had to let the car cool before it would grip again.
You want an unsprung disk? Yikes man....hope you have some spare trannies
Daikin is the best clutch
I have the Daikin twin plate clutch in both my rally Evo 6 and my road Evo 7 and they both work great. No slip, no judder and a light pedal pressure.
The only drawback is that the clutch and replacement plates are expensive and hard to find.
I got one from TAD Motorsports and the other from Daikin in Australia directly.
Cost of the clutch and flywheel assembly complete was US$1,300 - so they are a bit expensive.
interesting... we didn't have that problem.
I'm a slight slipper, not a clutch ripper, so an unsprung disk offers more longevity... how you ask? Fewer parts (read springs) to come apart on me... it's easy on the friction surfaces, and with the right pressure plate (the secret to any good clutch, much less Kevlar), engagement can be great too. The only real problem with most unsprung clutches is the travel/design of the plate. Most offerings compromise engagement for the sake of ultimate clamping pressure in order to force enough bite with Kevlar... I need to see if Action Clutch might be interested in whipping something up. I've had good results with them... Of course I'm not ruling out your above mentioned units.
Re: Clutch Replacement
