Helix Rods.. is anyone using them?
I'm planning to forge my engine. I'm completely decided to put Wiseco or Ross piston, but about the rod I do not have a clue. I've found information about crower, oliver and pautter rods, and they seems to be ok for more than 800 whp. I'm planning to get a max of 500 whp, then the rods named aboved are kind of overspecified (wich is not bad) but trough this forums I came across with the Helix Rods.
I did the rule Nē1 (The Search Buttom), and I couldn't find any dynos sheets, feedback or comment about Helix Rods set ups.
Is anyone using this rods?
How much HP they can hold?
Gruppe-S is the only one dealer for them?
Thanks you all
Thanks you all
I do not want to be guinea pig for Helix rods, but I remember in the page of gruppe-s says:
Helix Connecting Rods - 03+ EVO
-ARP L19 Rod Bolts
-4340 H Beam design, shot peened, magnafluxed
-Up to 800HP
is the same as the Eagle...
I jut want to confirm the 800 hp, and this will means they aren`t the same as Eagle...
I'm running them in my Gruppe-S stroker, but I'm still breaking in the engine. The rods haven't broken, so they'll hold at least 400 whp for a few pulls. Gruppe-S rates their stroker block with the Helix rods conservatively at 600hp, so they should be good enough for at least that.
-Paul
-Paul
RSMike
Aug 6, 2011 11:55 AM
Gruppe-S
29
Nov 30, 2006 01:18 PM
Turd Squirter
11
Feb 22, 2006 02:57 PM
